I wanted to give a try to the ChibiStudio for Linux; in the installation instructions it's said that "There is a known issue: Debug launch configurations in ChibiOS projects must be manually updated, select "OpenOCD TCP/IP" as protocol then everything should work. Launch configurations will be eventually updated in ChibiOS but that will happen when also ChibiStudio for Windows will be updated."
I've tried to identify where to change that protocol, but I'm unable to find it.
Anybody would be so kind as to give me a hint on where to change it?
Thanks a lot!
Joaquin
ChibiStudio Linux debug protocol
- Has thanked: 1074 times
- Been thanked: 921 times
Re: ChibiStudio Linux debug protocol
From the debug drop down meno (the bug icon in the toolbar):
- Select "Debug Configurations...".
- Open "GDB Hardware Debugging" and select the launch configuration inside (it is the one of the currently opened project).
- Select the "Debugger" tab.
- In the "JTAG Device" drop down change from "Generic TCP/IP" to "OpenOCD via socket".
- Apply, Close.
- Apply, Close.
