hi, i have installed chibios on my surface pro 4 and i have noticed that the icons on the top bar are really small and hence difficult to use,
i think this is due to the non conventional resolution ( 2700x1800 circa) and aspect-ratio (3:2), but i suppose it's a common issue for everyone with a monitor with a resolution higher than the standard 1080p. is there any option available in chibistudio to increase the dimensions of the top bar?
chibistudio shows really small icons on surface pro 4
Re: chibistudio shows really small icons on surface pro 4
ChibiStudio is plain Eclipse, I googled for that, found some possible solutions:
https://mcuoneclipse.com/2017/10/11/dea ... -displays/
https://developers.perfectomobile.com/d ... on+laptops
thanks, i adopted the first solution and the problem was solved
