Hi guys,
I commend all your efforts on the development of the ChibiOS, I believe I can contribute too when I understand the platform very well.
I am new to ChibiStudio and I'm having difficulties setting it up on my windows, I followed the steps given by PlayEmbedded but I get Java runtime errors whenever I try to run the ChibiStudio shortcut. I also followed a guide on how to import my ChibiOS demos to eclipse but no make path found.
I switched to back to windows because of using ChibiStudio, I will also appreciate if there are guides to use ChibiStudio on Linux (Ubuntu).
I really need help on this as I want to master all the ChibiOS in weeks.
Setting up ChibiStudio
- nerdELinux
- Has thanked: 5 times
- Been thanked: 1 time
- Has thanked: 1074 times
- Been thanked: 921 times
Re: Setting up ChibiStudio
Have you tried the Linux Mint VM we provide with everything preinstalled?
You could try it then migrate the setup in your Linux of choice.
- nerdELinux
I think using VM slows down my PC so i'm avoiding using it, I will try to use it directly on Ubuntu.
Also setting up ChibiStudio on Windows 10, I get this error and trying to launch the shortcut
https://drive.google.com/file/d/13_VrVCz_8rjiYhb7mpHikBeWe_YLjYL3/view?usp=drivesdk
Using Eclipse setup directly, I get this error
https://drive.google.com/file/d/1--4wDWjlyWWXKm-PD1Sx2ecjSbTb5-ER/view?usp=drivesdk
If others can do it, You can do it better.
You need to launch ChibiStudio using the provided shortcut, your path variable is not set apparently, that is done in a batch file launched by the shortcut.
- nerdELinux
Thank you Giovanni, I installed the JRE 32-bit on my Windows and now everything seem okay....
