Can't run and debug code
nerdELinux
Has thanked: 5 times
Postby nerdELinux » Mon Aug 26, 2019 3:50 pm
Hi guys,
I'm having problems running and debugging my codes on ChibiStudio.
Thanks in advance,
If others can do it, You can do it better.
Re: Can't run and debug code
Postby Giovanni » Mon Aug 26, 2019 8:25 pm
No clue, never seen that and that image shows nothing of interest. Make sure to use a standard setup initially, following play-embedded videos usually works.
mikeprotts
Has thanked: 19 times
Been thanked: 31 times
Postby mikeprotts » Mon Aug 26, 2019 9:59 pm
I'd suggest seeing if gdb works outside of the eclipse environment. The Details button might give more info, but from the screenshot it's not possible to tell if gdb is not being found, or if it is found but has some form of error.
Mike
nerdELinux
Postby nerdELinux » Tue Aug 27, 2019 8:01 am
Thanks for the reply, yes mikeprotts it's not seeing the gdb... complaining of Cannot run program gdb check the debug settings below
mikeprotts
Postby mikeprotts » Tue Aug 27, 2019 6:45 pm
Did the compile stage run OK, no errors or warnings? That means rebuilding everything, in case something old was left around.
Have you checked that gdb exists and is in a directory that is picked up by the Eclipse settings?
Are you using the standard current ChibiStudio installation, and using the shortcut to launch?
Mike
nerdELinux
Postby nerdELinux » Tue Aug 27, 2019 7:57 pm
Hi mikeprotts, The code compiled successfully, i will check if gdb exist buh i am using the ChibiStudio Shortcut launch..
nerdELinux
Postby nerdELinux » Wed Aug 28, 2019 2:54 pm
It works now, I remained the gdb to arm-none-eabi-gdb
Thanks
mikeprotts
Postby mikeprotts » Wed Aug 28, 2019 7:46 pm
Simple fixes are the best. And thanks for posting that here as it will no doubt help others in the future.
Mike
Return to “ChibiStudio”
Users browsing this forum: No registered users and 37 guests
