Compile with Make on WSL
JSStabl
Has thanked: 3 times
Been thanked: 2 times
Postby JSStabl » Fri Feb 28, 2020 10:42 am
I'm trying to setup to compile my chibiOS project to comile with make (and eventually cmake) from my wsl bash. I'm using a modified version of the newest example for the
RT-STM32F767ZI-NUCLEO144
Now, when I go to the project directory and simply type make -j8 (as i is in chibiOS), I get
.dep/hal_spi.o.d:1: *** multiple target patterns.  Stop.
I assume theres something missing on my toolchain. I was able to compile a different chibiOS project (the vesc firmware) with this method though.
Are there any settings I need to set before I can compile this? Couldn't fine any in eclipse itself. Googling the issue brings up spaces in the path (which i dont have) and some other weird issues, but since it compiles fine in chibiStudio (under windows) it's probably a configuration issue.
I'm using make version 4.1 and my gcc is on 7.4.0.
JSStabl
Re: Compile with Make on WSL
Postby JSStabl » Fri Feb 28, 2020 12:45 pm
Solved, compiled under windows beforehand. Delete the .dep and run make clean. Then it compiles under ubuntu with make 4.2.1.
Postby Giovanni » Fri Feb 28, 2020 1:58 pm
Make sure to use GNU make, the one from MinGW is fine.
Return to “ChibiStudio”
