Running Linux.
I'm trying to use ChibiStudio to generate a board config for a custom STM32F4 design. I'd like to import a demo using a similar MCU and then reconfigure all the pins and such.
I've installed ChibiStudio, opened the a workspace, and can see all the projects on the left. But when I try to open one, it errors saying that there's no .project file. A quick ls shows that there is indeed a project file there.
I tried to find some documentation on using ChibiStudio but I couldn't find anything.
Any assistance would be greatly appreciated.
Thank you
ChibiStudio documentation?
Re: ChibiStudio documentation?
You need to install ChibiStudio exactly as C:\ChibiStudio or paths are broken and you need several adjustments.
A lot of tutorials are on http://playembedded.org
The linux version needs adjustments because it assumes /home/xxxxxx for my setup. You may try the Linux VM with everything installed.
Users browsing this forum: No registered users and 31 guests
