I'm trying to compile and get the below demo project to work on the below Olimex STM32_407 board.
https://www.olimex.com/Products/ARM/ST/ ... 2-E407.pdf
I've cloned from GH Chibios, and found this demo-project.
C:\ChibiStudio\chibios203\demos\STM32\RT-STM32-LWIP-FATFS-USB
I extracted some compressed files, then commented out some stuff relative to FAT and the MMC. It compiles now without errors. I can put this compiled version in the Olimex board via STVP or DfuSe. However I expect a LED to blink which does not blink, as well the HTTP should respond to some IP traffic, but it appears to be non-responsive. My next incremental step is an attempt to get SWD debugging operational. So I can attempt to better understand why it has failed to blink the LED.
I have a STM32F4 discovery. I have programmed this discovery with the RT-STM32F407-DISCOVERY demo project. I then moved the SCLK and SWDIO wires via a jumper to the Olimex board. I have programmed the Olimex board using ST's STVP program. With STVP I can erase, read or program the Olimex board via SWD interface. I'm now trying to get ChibiOS to do the same, with hopes that I'll get break point capabilities.
In RT-STM32-LWIP-FATFS-USB I have selected the .elf file and pull down "Create OpenOCD Debug Configuration (pre-select elf file into a project)", then the console says Done as shown in the below picture. However I do not get the .launch files and I do not get the debug folder. How do I get the .launch files? Or more important, how do I get the SWD debugger operational?
Other misc information, this is Win10 64bit with ChibiStudio_Windows_2020-04.7z and I have launched Eclipse via Chibi Studio GCC 9.0 shortcut.
STLink / discovery on Demo project
Re: STLink / discovery on Demo project
Is there a ./tools/fmpp directory in your Chibistudio?
After generating the debug configuration try refreshing the project, it should have created a ./debug directory, the .launch is inside.
F5 for refresh was the magic. It now has debug folder and SWD is operating as expected. Now I need to figure out why it's not making it to the main loop. Seems it goes to a handler as noted in the attached picture.
- Untitled.png (7.22 KiB) Viewed 4258 times
Apparently it is crashing before reaching the main function, you may try to place a break point in the early init code in board.c.
- russian
- Has thanked: 16 times
- Been thanked: 14 times
Since you have debugger you can now step-over from start and see how far this makes prior to the crash?
http://rusefi.com/ - electronic fuel injection
Users browsing this forum: No registered users and 24 guests
