Linux debug configuration
steved
Has thanked: 12 times
Been thanked: 135 times
Re: Linux debug configuration
Postby steved » Sun Apr 09, 2023 8:47 am
Giovanni wrote:Hi,
Yes, the current setup is to have one workspace for each version. You could mix projects but then you could not rely on the workspace variable CHIBIOS in project virtual folders (board, os, test, etc).
Another question, I'm afraid. When running openOCD, do you run it as root? Or have you set up some udev rules?
Postby Giovanni » Sun Apr 09, 2023 9:05 am
There are udev rules in the openocd folder, just place them like this:
You also need to add the group "dialout" to your user if I remember well.
steved
Postby steved » Sun Apr 09, 2023 10:40 pm
Sorry, but no sign of a directory with udev rules in it.
And some of the tools for launching OpenOCD mention version 12 (binary name openocd_12); that doesn't appear to be present either.
Postby Giovanni » Mon Apr 10, 2023 7:27 am
Sorry, my mistake, most of those are in the STM32 Cube Programmer under:
/STMicroelectronics/STM32Cube/STM32CubeProgrammer/Drivers/rules
A big rules file is in OpenOCD under, it should include everything:
/ChibiStudio/tools/openocd/contrib/libdcc60-openocd.rules
Probably you only really need this one.
steved
Postby steved » Mon Apr 10, 2023 10:47 am
Thanks that worked. Probably my remaining niggles are due to the age and type of the Nucleo board I'm using (not sure that serial over USB should work with the L031).
I've generated some notes on the process, which you're welcome to incorporate.
ChibiStudio_Linux_Install.7z
(1.46 KiB) Downloaded 156 times
Return to “ChibiStudio”
