Weird SPI driver behavior on STM32H750 Topic is solved
djedski30
Post by djedski30 »
I'm trying to transmit data over SPI and am finding that how the TX buffer is declared matters. I seem to only get it to work if the TX buffer is a static buffer. If it's a local variable, I get a halt. I'm on the HEAD of master (as of today) and am running on the STM32H750XB Discovery board. Below is my patch. In there, I have 3 ways to initialize the TX buffer. Theoretically, all 3 should work, but only the static buffer that's initialized works.
If I use a local variable, it halts and here's the call stack:
chSysHalt() at chsys.c:133 0x8000672
osalSysHalt() at osal.h:544 0x80006ee
spi_lld_serve_dma_tx_interrupt() at hal_spi_lld.c:202 0x80006ee
Vector70() at stm32_dma.c:188 0x8002b90
Please have a look at my patch as well. Appreciate the help!
diff --git a/demos/STM32/RT-STM32H750XB-DISCOVERY/cfg/halconf.h b/demos/STM32/RT-STM32H750XB-DISCOVERY/cfg/halconf.h
index cdbad17f1..2ead6f3f3 100644
--- a/demos/STM32/RT-STM32H750XB-DISCOVERY/cfg/halconf.h
+++ b/demos/STM32/RT-STM32H750XB-DISCOVERY/cfg/halconf.h
@@ -163,7 +163,7 @@
* @brief Enables the SPI subsystem.
#if !defined(HAL_USE_SPI) || defined(__DOXYGEN__)
-#define HAL_USE_SPI FALSE
+#define HAL_USE_SPI TRUE
diff --git a/demos/STM32/RT-STM32H750XB-DISCOVERY/cfg/mcuconf.h b/demos/STM32/RT-STM32H750XB-DISCOVERY/cfg/mcuconf.h
index b6a9cc38b..8720c5ec5 100644
--- a/demos/STM32/RT-STM32H750XB-DISCOVERY/cfg/mcuconf.h
+++ b/demos/STM32/RT-STM32H750XB-DISCOVERY/cfg/mcuconf.h
@@ -393,7 +393,7 @@
* SPI driver system settings.
#define STM32_SPI_USE_SPI1 FALSE
-#define STM32_SPI_USE_SPI2 FALSE
+#define STM32_SPI_USE_SPI2 TRUE
#define STM32_SPI_USE_SPI3 FALSE
#define STM32_SPI_USE_SPI4 FALSE
#define STM32_SPI_USE_SPI5 FALSE
diff --git a/demos/STM32/RT-STM32H750XB-DISCOVERY/main.c b/demos/STM32/RT-STM32H750XB-DISCOVERY/main.c
index 744cb4ffd..1657a2508 100644
--- a/demos/STM32/RT-STM32H750XB-DISCOVERY/main.c
+++ b/demos/STM32/RT-STM32H750XB-DISCOVERY/main.c
@@ -39,6 +39,15 @@ static THD_FUNCTION(Thread1, arg) {
chThdSleepMilliseconds(200);
+static const SPIConfig spi2_cfg = {
+ false,
+ NULL,
+ IOPORT2,
+ 4,
+ SPI_CFG1_MBR_DIV8 | SPI_CFG1_DSIZE_VALUE(7),
+ 0
* Application entry point.
@@ -55,6 +64,49 @@ int main(void) {
+ * SPI2 I/O pins setup.
+ palSetPadMode(GPIOD, 3, PAL_MODE_ALTERNATE(5) | PAL_STM32_OSPEED_HIGHEST); /* SPI SCK. */
+ palSetPadMode(GPIOI, 2, PAL_MODE_ALTERNATE(5) | PAL_STM32_OSPEED_HIGHEST); /* MISO. */
+ palSetPadMode(GPIOB, 15, PAL_MODE_ALTERNATE(5) | PAL_STM32_OSPEED_HIGHEST); /* MOSI. */
+ palSetPad(GPIOB, 4);
+ palSetPadMode(GPIOB, 4, PAL_MODE_OUTPUT_PUSHPULL); /* CS0. */
+ spiStart(&SPID2, &spi2_cfg);
+ * Case 1: static var initialized = works. SPI sends 0xA5
+// static uint8_t txbuf = 0xA5;
+ * Case 2: static var initialzied and assigned at runtime = fails, SPI sends 0xA5 instead of 0xFF
+// txbuf = 0xFF;
+ * Case 3: local var = fails, spiSend() hangs
+ uint8_t txbuf = 0xA5;
+ spiAcquireBus(&SPID2);
+ while (1)
+ spiSelect(&SPID2);
+ spiSend(&SPID2, sizeof(txbuf), &txbuf);
+ spiUnselect(&SPID2);
+ chThdSleepMilliseconds(500);
+ spiReleaseBus(&SPID2);
* Activates the serial driver 1 using the driver default configuration.
Re: Weird SPI driver behavior on STM32H750
SPI buffers have to be placed in DMA-accessible areas, is your stack placed into an accessible RAM?
djedski30
Post by djedski30 »
Sorry, how do I check if my stack is placed into accessible RAM? I'm just using the demo code demos/STM32/RT-STM32H750XB-DISCOVERY/main.c
Placement is defined in the linker file included by the makefile, the default ones puts the C stack in TCM which is not DMA-accessible.
The easy approach is to use static buffers.
