STM32F767zi: ICM200948 over SPI
tsm
Postby tsm » Sun Jun 13, 2021 7:55 pm
I'm working on a driver for this IMU device on some custom hardware based on the stm32f767zi. There might be something wrong with my configuration as I can't read the device's ID.
This is what I have currently:
relevant parts from board.h
#define GPIOB_SPI2_NSS               12U
#define GPIOB_SPI2_SCK               13U
#define GPIOB_SPI2_MISO              14U
#define GPIOB_SPI2_MOSI              15U
#define LINE_SPI2_NSS                PAL_LINE(GPIOB, 12U)
#define LINE_SPI2_SCK                PAL_LINE(GPIOB, 13U)
#define LINE_SPI2_MISO              PAL_LINE(GPIOB, 14U)
#define LINE_SPI2_MOSI              PAL_LINE(GPIOB, 15U)
PIN_MODE_OUTPUT(GPIOB_SPI2_NSS) |                \
PIN_MODE_ALTERNATE(GPIOB_SPI2_SCK) |           \
PIN_MODE_ALTERNATE(GPIOB_SPI2_MISO) |          \
PIN_MODE_ALTERNATE(GPIOB_SPI2_MOSI))
PIN_OTYPE_PUSHPULL(GPIOB_SPI2_NSS) |       \
PIN_OTYPE_PUSHPULL(GPIOB_SPI2_SCK) |        \
PIN_OTYPE_PUSHPULL(GPIOB_SPI2_MISO) |       \
PIN_OTYPE_PUSHPULL(GPIOB_SPI2_MOSI))
PIN_OSPEED_HIGH(GPIOB_SPI2_NSS) |          \
PIN_OSPEED_HIGH(GPIOB_SPI2_SCK) |          \
PIN_OSPEED_HIGH(GPIOB_SPI2_MISO) |        \
PIN_OSPEED_HIGH(GPIOB_SPI2_MOSI))
PIN_PUPDR_FLOATING(GPIOB_SPI2_NSS) |      \
PIN_PUPDR_FLOATING(GPIOB_SPI2_SCK) |      \
PIN_PUPDR_FLOATING(GPIOB_SPI2_MISO) |    \
PIN_PUPDR_FLOATING(GPIOB_SPI2_MOSI))
PIN_AFIO_AF(GPIOB_SPI2_NSS, 0U) |       \
PIN_AFIO_AF(GPIOB_SPI2_SCK, 5U) |       \
PIN_AFIO_AF(GPIOB_SPI2_MISO, 5U) |      \
PIN_AFIO_AF(GPIOB_SPI2_MOSI, 5U))
This is the SPI configuration I'm setting:
static const SPIConfig SPID2_CONFIG = {
    // circular mode
    .circular = false,
    // callback
    .end_cb = nullptr,
    // chip select port
    .ssport = GPIOB,
    // chip select pad number
    .sspad = GPIOB_SPI2_NSS,
    // control register 1
    .cr1 = SPI_CR1_BR_0 | SPI_CR1_CPOL | SPI_CR1_CPHA,
    // control register 2
    .cr2 = SPI_CR2_DS_0 | SPI_CR2_DS_1 | SPI_CR2_DS_2
Then after calling spiStart I just call spiExchange to read from the proper register where the device ID should be. I'm controlling chip select with spiSelect. I'm not very experience with SPI so I might failing to configure properly the pins?
Thank you
Has thanked: 890 times
Been thanked: 770 times
Re: STM32F767zi: ICM200948 over SPI
Postby Giovanni » Sun Jun 13, 2021 8:35 pm
If you use spiSelect() then NSS should be a normal GPIO output.
tsm
Postby tsm » Sun Jun 13, 2021 9:01 pm
thanks for taking the time.
I'm not sure what you mean. Isn't the configuration I showed for NSS PIN_MODE_OUTPUT(GPIOB_SPI2_NSS) , etc enough to set it as an output GPIO?
Best
Postby Giovanni » Mon Jun 14, 2021 7:50 am
I think you should look at signals using a logic analyser, that would help understanding the problem. Do you see anything on those pins?
rew
Has thanked: 2 times
Been thanked: 13 times
Postby rew » Thu Jun 17, 2021 3:18 pm
Giovanni's first remark is on target:
The hardware CAN do something with the NSS line, but chibios considers that "not handy to work with", so the driver expects the NSS pin to be GPIO, and when it needs it low, it will simply palClearPad (spicfg->ssport, spicfg->sspad);
Return to “STM32 Support”
