Im currently using an STM32F407 Discovery board, and presently attempting to set PIN4 of PORTC to trigger an interrupt routine when either a rising or falling edge is detected. I've been through the reference manual and as far as I can see I have everything setup correctly, yet the interrupt isn't triggered when I apply +3V to the pin.
My code setting up the EXTI on PORTC Pin4, and interrupt routine is as follows, my thinking is that this should be a very simple problem fix for someone in the know. Unfortunately I am not able to use the libraries as I am need to become intimately familiar with the device (college). Thank you very much for any help offered.
RCC->AHB1ENR |=(1<<2); //Enable PORTC Clock
GPIOC->OSPEEDR |=(1<<9); //Enable high speed for pin 4
GPIOC->PUPDR |=(1<<9); //Pull down resistor for pin 4
SYSCFG->EXTICR[2] |=(0x02); //Enable EXTI on PORTC Pin4
EXTI->IMR |=(1<<4);
EXTI->RTSR |=(1<<4);
EXTI->FTSR |=(1<<4);
NVIC_EnableIRQ(EXTI4_IRQn);
void EXTI4_IRQHandler(void)
while(1)
printf("sucess!!");
EXTI->PR|=0x010;
