ChibiOS crashes when my firmware is not at beginning of flash memory
kalpesh
Re: ChibiOS crashes when my firmware is not at beginning of flash memory
Postby kalpesh » Wed Mar 11, 2020 5:57 am
How to set the VTOR in chibios ?
For HAL application:
I am setting the VTOR in .ld file of the sample application code.
I am only setting flash0 : org = 0x08020000, len = 512k in .ld file of chibios. Also if bootloader jumps to application address, then it starts executing from main ( halinit() and chsysinit() is part of main function). Am I correct ?
Thanks
steved
Has thanked: 10 times
Been thanked: 122 times
Postby steved » Wed Mar 11, 2020 5:40 pm
You also need to set flash1 value in the scatter file; as far as I can remember that's all I did.
Can't remember why, but setting flash0 and flash1 to the same value worked for me.
kalpesh
Postby kalpesh » Thu Mar 12, 2020 11:40 am
Where is the scatter file located or what is the exact name of this scatter file.
Also do I need to set the same value in flash 1 as I set in flash 0 or some other value.
Thanks
Return to “STM32 Support”
