Has thanked: 888 times
Been thanked: 768 times
Postby Giovanni » Fri Jul 19, 2019 7:44 am
Hi Tridge,
I will look into this in the weekend. I slowed down a bit on the H7 because the new revision that changed quite a bit of things, I am waiting boards with the updated device and with the new one with two cores.
tridge
Has thanked: 8 times
Been thanked: 19 times
Postby tridge » Fri Jul 19, 2019 8:08 am
Giovanni wrote:I will look into this in the weekend. I slowed down a bit on the H7 because the new revision that changed quite a bit of things, I am waiting boards with the updated device and with the new one with two cores.
no worries, I'm looking fwd to getting one of those new ones too.
tridge
Postby tridge » Fri Jul 19, 2019 11:48 am
note that there was a typo in my I2Cv3 change, mixup of rx and tx
tridge
Postby tridge » Mon Nov 25, 2019 8:58 am
I received my first boards with the new RevisionV of the H743 chip today. It was a lot less hassle than I expected. It turns out our existing ArduPilot code runs on it fine with no changes. That is partly luck because of ADC clocking choices, but it certainly makes our life easy.
I haven't yet tried to enable the VOS0 voltage scaling to allow for 480MHz. We'll try that soon. I'm hoping we can do that as a runtime change based on the chip revision so we don't need to ship two different firmwares.
Either way, the gloomy predictions for how hard it was going to be to support both RevY and RevV turn out to be a bit over-stated. At least for ArduPilot it has been trivially easy.
Postby Giovanni » Mon Nov 25, 2019 11:08 am
Good to know, I will resume work on this next. Is support for the old revision still required? probably there are lots of parts on the field.
tridge
Postby tridge » Mon Nov 25, 2019 1:20 pm
Giovanni wrote:Good to know, I will resume work on this next. Is support for the old revision still required? probably there are lots of parts on the field.
We will certainly need to support both revY and revV for quite a few years in ArduPilot (usual lifetime would be 5 years or so). Luckily that won't be hard.
elagil
Has thanked: 7 times
Been thanked: 5 times
Postby elagil » Tue Nov 26, 2019 1:22 pm
Was development on a MACv2 driver already started? If so, I would like to contribute, since I need this functionality for some projects.
Postby Giovanni » Tue Nov 26, 2019 1:24 pm
MACv2 is not started yet, I still have to assess differences with the old one.
Re: progress on SDMMCv2 on H7
Postby Giovanni » Mon Jan 13, 2020 6:55 pm
tridge wrote:I made some more progress on SDMMCv2 on a H743. I still don't have IDMA working, but I do have a working polled driver. I can access flight logs in ArduPilot now, and create logs. I've attached the current version.
Only polled transfers work so far. I spent quite a bit of time today trying to get interrupt driven transfers working, but as yet they don't work. I do get some successful transactions, but pretty soon either get a lockup or data corruption. I've left the interrupt driven implementation in the driver, enabled for read and write using the SDMMC_POLLED_READ and SDMMC_POLLED_WRITE defines at the top of the driver. If anyone can spot what the issue is with interrupt driven mode that would be great.
Of course what we really want is IDMA working, but so far I've had no luck with that. See my previous question about triggers.
Cheers, Tridge
Just FYI, I am giving IDMA a try, it does not look complex.
tridge
Postby tridge » Mon Jan 13, 2020 8:40 pm
sorry, I thought I told you that I got IDMA fully working last year. I think I sent a patch?
The code is here:
https://github.com/ArduPilot/ChibiOS/bl ... _sdc_lld.c
We've been using it in production with ArduPilot for some months now. It works well.
Return to “STM32 Support”
