Another CDC/USB issue - 407ZGT6 minimum board
AmperCZ
Postby AmperCZ » Tue Mar 17, 2020 9:02 am
Hi
trying to get CDC working on chinese 407 minimum board (I have code ready on 407 Disco and want to put smaller board in robot)
Board is relativelly minimum (from USB standpoint) with V bus directly to 5VIn, ID grounded, D-/+ connected to PA11/12 throught 22R resistor and D+ is pulled up with 1.5k
There is 25Mhz osc and also 32.768 osc32. I changed timings accordingly CubeMX and by led time it looks somehow correct.
But SDU1 doesn't get recognized as CDC - same code as I had in Disco where it worked.
Board.h is changed so additional usb pins from Disco is removed, #define BOARD_OTG_NOVBUSSENS addede on beginning of board.h and still not luck. I scanned what I found on forum on CDC and still don't know what I am doing wrong :-(
board.h
#ifndef BOARD_H
#define BOARD_H
/* Driver constants.                                                         */
 * Setup for STMicroelectronics STM32F4-Discovery board.
 * Board identifier.
#define BOARD_ST_STM32F4MINI
#define BOARD_NAME                  "STM32F407Mini"
 * Board oscillators-related settings.
 * NOTE: LSE not fitted.
#define STM32_LSECLK                32768U
#define STM32_HSECLK                25000000U
 * Board voltages.
 * Required for performance limits calculation.
#define STM32_VDD                   330U
 * MCU type as defined in the ST header.
#define STM32F407xx
 * IO pins assignments.
#define GPIOA_BUTTON                0U
#define GPIOA_PIN1                  1U
#define GPIOA_PIN2                  2U
#define GPIOA_PIN3                  3U
#define GPIOA_LRCK                  4U
#define GPIOA_SPC                   5U
#define GPIOA_SDO                   6U
#define GPIOA_SDI                   7U
#define GPIOA_PIN8                  8U
#define GPIOA_OTG_FS_DM             11U
#define GPIOA_OTG_FS_DP             12U
#define GPIOA_SWDIO                 13U
#define GPIOA_SWCLK                 14U
#define GPIOA_PIN15                 15U
#define GPIOB_PIN0                  0U
#define GPIOB_PIN1                  1U
#define GPIOB_PIN2                  2U
#define GPIOB_SWO                   3U
#define GPIOB_PIN4                  4U
#define GPIOB_PIN5                  5U
#define GPIOB_SCL                   6U
#define GPIOB_PIN7                  7U
#define GPIOB_PIN8                  8U
#define GPIOB_SDA                   9U
#define GPIOB_CLK_IN                10U
#define GPIOB_PIN11                 11U
#define GPIOB_PIN12                 12U
#define GPIOB_PIN13                 13U
#define GPIOB_PIN14                 14U
#define GPIOB_PIN15                 15U
 * IO lines assignments.
#define LINE_BUTTON                 PAL_LINE(GPIOA, 0U)
#define LINE_LRCK                   PAL_LINE(GPIOA, 4U)
#define LINE_SPC                    PAL_LINE(GPIOA, 5U)
#define LINE_SDO                    PAL_LINE(GPIOA, 6U)
#define LINE_SDI                    PAL_LINE(GPIOA, 7U)
#define LINE_VBUS_FS                PAL_LINE(GPIOA, 9U)
#define LINE_OTG_FS_ID              PAL_LINE(GPIOA, 10U)
#define LINE_OTG_FS_DM              PAL_LINE(GPIOA, 11U)
#define LINE_OTG_FS_DP              PAL_LINE(GPIOA, 12U)
#define LINE_SWDIO                  PAL_LINE(GPIOA, 13U)
#define LINE_SWCLK                  PAL_LINE(GPIOA, 14U)
#define LINE_SWO                    PAL_LINE(GPIOB, 3U)
#define LINE_SCL                    PAL_LINE(GPIOB, 6U)
#define LINE_SDA                    PAL_LINE(GPIOB, 9U)
#define LINE_CLK_IN                 PAL_LINE(GPIOB, 10U)
#define LINE_OTG_FS_POWER_ON        PAL_LINE(GPIOC, 0U)
#define LINE_PDM_OUT                PAL_LINE(GPIOC, 3U)
#define LINE_MCLK                   PAL_LINE(GPIOC, 7U)
#define LINE_SCLK                   PAL_LINE(GPIOC, 10U)
#define LINE_SDIN                   PAL_LINE(GPIOC, 12U)
#define LINE_RESET                  PAL_LINE(GPIOD, 4U)
#define LINE_OVER_CURRENT           PAL_LINE(GPIOD, 5U)
#define LINE_LED4                   PAL_LINE(GPIOD, 12U)
#define LINE_LED3                   PAL_LINE(GPIOD, 13U)
#define LINE_LED5                   PAL_LINE(GPIOD, 14U)
#define LINE_LED6                   PAL_LINE(GPIOD, 15U)
#define LINE_INT1                   PAL_LINE(GPIOE, 0U)
#define LINE_INT2                   PAL_LINE(GPIOE, 1U)
#define LINE_CS_SPI                 PAL_LINE(GPIOE, 3U)
#define LINE_OSC_IN                 PAL_LINE(GPIOH, 0U)
#define LINE_OSC_OUT                PAL_LINE(GPIOH, 1U)
/* Driver pre-compile time settings.                                         */
/* Derived constants and error checks.                                       */
/* Driver data structures and types.                                         */
/* Driver macros.                                                            */
 * I/O ports initial setup, this configuration is established soon after reset
 * in the initialization code.
 * Please refer to the STM32 Reference Manual for details.
#define PIN_MODE_INPUT(n)           (0U << ((n) * 2U))
#define PIN_MODE_OUTPUT(n)          (1U << ((n) * 2U))
#define PIN_MODE_ALTERNATE(n)       (2U << ((n) * 2U))
#define PIN_MODE_ANALOG(n)          (3U << ((n) * 2U))
#define PIN_ODR_LOW(n)              (0U << (n))
#define PIN_ODR_HIGH(n)             (1U << (n))
#define PIN_OTYPE_PUSHPULL(n)       (0U << (n))
#define PIN_OTYPE_OPENDRAIN(n)      (1U << (n))
#define PIN_OSPEED_VERYLOW(n)       (0U << ((n) * 2U))
#define PIN_OSPEED_LOW(n)           (1U << ((n) * 2U))
#define PIN_OSPEED_MEDIUM(n)        (2U << ((n) * 2U))
#define PIN_OSPEED_HIGH(n)          (3U << ((n) * 2U))
#define PIN_PUPDR_FLOATING(n)       (0U << ((n) * 2U))
#define PIN_PUPDR_PULLUP(n)         (1U << ((n) * 2U))
#define PIN_PUPDR_PULLDOWN(n)       (2U << ((n) * 2U))
#define PIN_AFIO_AF(n, v)           ((v) << (((n) % 8U) * 4U))
 * GPIOA setup:
 * PA0  - BUTTON                    (input floating).
 * PA1  - PIN1                      (input pullup).
 * PA2  - PIN2                      (input pullup).
 * PA3  - PIN3                      (input pullup).
 * PA4  - LRCK                      (alternate 6).
 * PA5  - SPC                       (alternate 5).
 * PA6  - SDO                       (alternate 5).
 * PA7  - SDI                       (alternate 5).
 * PA8  - PIN8                      (input pullup).
 * PA9  - VBUS_FS                   (input floating).
 * PA10 - OTG_FS_ID                 (alternate 10).
 * PA11 - OTG_FS_DM                 (alternate 10).
 * PA12 - OTG_FS_DP                 (alternate 10).
 * PA13 - SWDIO                     (alternate 0).
 * PA14 - SWCLK                     (alternate 0).
 * PA15 - PIN15                     (input pullup).
#define VAL_GPIOA_MODER             (PIN_MODE_INPUT(GPIOA_BUTTON) |         \
                                     PIN_MODE_INPUT(GPIOA_PIN1) |           \
                                     PIN_MODE_INPUT(GPIOA_PIN2) |           \
                                     PIN_MODE_INPUT(GPIOA_PIN3) |           \
                                     PIN_MODE_ALTERNATE(GPIOA_LRCK) |       \
                                     PIN_MODE_ALTERNATE(GPIOA_SPC) |        \
                                     PIN_MODE_ALTERNATE(GPIOA_SDO) |        \
                                     PIN_MODE_ALTERNATE(GPIOA_SDI) |        \
                                     PIN_MODE_INPUT(GPIOA_PIN8) |           \
                                     PIN_MODE_ALTERNATE(GPIOA_OTG_FS_DM) |  \
                                     PIN_MODE_ALTERNATE(GPIOA_OTG_FS_DP) |  \
                                     PIN_MODE_ALTERNATE(GPIOA_SWDIO) |      \
                                     PIN_MODE_ALTERNATE(GPIOA_SWCLK) |      \
                                     PIN_MODE_INPUT(GPIOA_PIN15))
#define VAL_GPIOA_OTYPER            (PIN_OTYPE_PUSHPULL(GPIOA_BUTTON) |     \
                                     PIN_OTYPE_PUSHPULL(GPIOA_PIN1) |       \
                                     PIN_OTYPE_PUSHPULL(GPIOA_PIN2) |       \
                                     PIN_OTYPE_PUSHPULL(GPIOA_PIN3) |       \
                                     PIN_OTYPE_PUSHPULL(GPIOA_LRCK) |       \
                                     PIN_OTYPE_PUSHPULL(GPIOA_SPC) |        \
                                     PIN_OTYPE_PUSHPULL(GPIOA_SDO) |        \
                                     PIN_OTYPE_PUSHPULL(GPIOA_SDI) |        \
                                     PIN_OTYPE_PUSHPULL(GPIOA_PIN8) |       \
                                     PIN_OTYPE_PUSHPULL(GPIOA_OTG_FS_DM) |  \
                                     PIN_OTYPE_PUSHPULL(GPIOA_OTG_FS_DP) |  \
                                     PIN_OTYPE_PUSHPULL(GPIOA_SWDIO) |      \
                                     PIN_OTYPE_PUSHPULL(GPIOA_SWCLK) |      \
                                     PIN_OTYPE_PUSHPULL(GPIOA_PIN15))
#define VAL_GPIOA_OSPEEDR           (PIN_OSPEED_HIGH(GPIOA_BUTTON) |        \
                                     PIN_OSPEED_HIGH(GPIOA_PIN1) |          \
                                     PIN_OSPEED_HIGH(GPIOA_PIN2) |          \
                                     PIN_OSPEED_HIGH(GPIOA_PIN3) |          \
                                     PIN_OSPEED_HIGH(GPIOA_LRCK) |          \
                                     PIN_OSPEED_MEDIUM(GPIOA_SPC) |         \
                                     PIN_OSPEED_MEDIUM(GPIOA_SDO) |         \
                                     PIN_OSPEED_MEDIUM(GPIOA_SDI) |         \
                                     PIN_OSPEED_HIGH(GPIOA_PIN8) |          \
                                     PIN_OSPEED_HIGH(GPIOA_OTG_FS_DM) |     \
                                     PIN_OSPEED_HIGH(GPIOA_OTG_FS_DP) |     \
                                     PIN_OSPEED_HIGH(GPIOA_SWDIO) |         \
                                     PIN_OSPEED_HIGH(GPIOA_SWCLK) |         \
                                     PIN_OSPEED_HIGH(GPIOA_PIN15))
#define VAL_GPIOA_PUPDR             (PIN_PUPDR_FLOATING(GPIOA_BUTTON) |     \
                                     PIN_PUPDR_PULLUP(GPIOA_PIN1) |         \
                                     PIN_PUPDR_PULLUP(GPIOA_PIN2) |         \
                                     PIN_PUPDR_PULLUP(GPIOA_PIN3) |         \
                                     PIN_PUPDR_FLOATING(GPIOA_LRCK) |       \
                                     PIN_PUPDR_FLOATING(GPIOA_SPC) |        \
                                     PIN_PUPDR_FLOATING(GPIOA_SDO) |        \
                                     PIN_PUPDR_FLOATING(GPIOA_SDI) |        \
                                     PIN_PUPDR_PULLUP(GPIOA_PIN8) |         \
                                     PIN_PUPDR_FLOATING(GPIOA_OTG_FS_DM) |  \
                                     PIN_PUPDR_FLOATING(GPIOA_OTG_FS_DP) |  \
                                     PIN_PUPDR_FLOATING(GPIOA_SWDIO) |      \
                                     PIN_PUPDR_FLOATING(GPIOA_SWCLK) |      \
                                     PIN_PUPDR_PULLUP(GPIOA_PIN15))
#define VAL_GPIOA_ODR               (PIN_ODR_HIGH(GPIOA_BUTTON) |           \
                                     PIN_ODR_HIGH(GPIOA_PIN1) |             \
                                     PIN_ODR_HIGH(GPIOA_PIN2) |             \
                                     PIN_ODR_HIGH(GPIOA_PIN3) |             \
                                     PIN_ODR_HIGH(GPIOA_LRCK) |             \
                                     PIN_ODR_HIGH(GPIOA_SPC) |              \
                                     PIN_ODR_HIGH(GPIOA_SDO) |              \
                                     PIN_ODR_HIGH(GPIOA_SDI) |              \
                                     PIN_ODR_HIGH(GPIOA_PIN8) |             \
                                     PIN_ODR_HIGH(GPIOA_OTG_FS_DM) |        \
                                     PIN_ODR_HIGH(GPIOA_OTG_FS_DP) |        \
                                     PIN_ODR_HIGH(GPIOA_SWDIO) |            \
                                     PIN_ODR_HIGH(GPIOA_SWCLK) |            \
                                     PIN_ODR_HIGH(GPIOA_PIN15))
#define VAL_GPIOA_AFRL              (PIN_AFIO_AF(GPIOA_BUTTON, 0U) |        \
                                     PIN_AFIO_AF(GPIOA_PIN1, 0U) |          \
                                     PIN_AFIO_AF(GPIOA_PIN2, 0U) |          \
                                     PIN_AFIO_AF(GPIOA_PIN3, 0U) |          \
                                     PIN_AFIO_AF(GPIOA_LRCK, 6U) |          \
                                     PIN_AFIO_AF(GPIOA_SPC, 5U) |           \
                                     PIN_AFIO_AF(GPIOA_SDO, 5U) |           \
                                     PIN_AFIO_AF(GPIOA_SDI, 5U))
#define VAL_GPIOA_AFRH              (PIN_AFIO_AF(GPIOA_PIN8, 0U) |          \
                                     PIN_AFIO_AF(GPIOA_OTG_FS_DM, 10U) |    \
                                     PIN_AFIO_AF(GPIOA_OTG_FS_DP, 10U) |    \
                                     PIN_AFIO_AF(GPIOA_SWDIO, 0U) |         \
                                     PIN_AFIO_AF(GPIOA_SWCLK, 0U) |         \
                                     PIN_AFIO_AF(GPIOA_PIN15, 0U))
/* External declarations.                                                    */
#if !defined(_FROM_ASM_)
#ifdef __cplusplus
extern "C" {
  void boardInit(void);
#ifdef __cplusplus
#endif /* _FROM_ASM_ */
#endif /* BOARD_H */
mcuconf.h
    ChibiOS - Copyright (C) 2006..2018 Giovanni Di Sirio
#ifndef MCUCONF_H
#define MCUCONF_H
 * STM32F4xx drivers configuration.
 * The following settings override the default settings present in
 * the various device driver implementation headers.
 * Note that the settings for each driver only have effect if the whole
 * driver is enabled in halconf.h.
 * IRQ priorities:
 * 15...0       Lowest...Highest.
 * DMA priorities:
 * 0...3        Lowest...Highest.
#define STM32F4xx_MCUCONF
 * HAL driver system settings.
#define STM32_HSI_ENABLED                   FALSE
#define STM32_LSI_ENABLED                   FALSE
#define STM32_LSE_ENABLED                   TRUE
#define STM32_CLOCK48_REQUIRED              TRUE
#define STM32_PLLM_VALUE                    25
#define STM32_PLLN_VALUE                    336
#define STM32_PLLP_VALUE                    2
#define STM32_PLLQ_VALUE                    7
#define STM32_PPRE1                         STM32_PPRE1_DIV4
#define STM32_PPRE2                         STM32_PPRE2_DIV2
#define STM32_RTCSEL                        STM32_RTCSEL_LSE
#define STM32_RTCPRE_VALUE                  2
#define STM32_MCO1SEL                       STM32_MCO1SEL_HSE
#define STM32_MCO1PRE                       STM32_MCO1PRE_DIV1
#define STM32_MCO2SEL                       STM32_MCO2SEL_SYSCLK
#define STM32_MCO2PRE                       STM32_MCO2PRE_DIV1
#define STM32_I2SSRC                        STM32_I2SSRC_CKIN
#define STM32_PLLI2SN_VALUE                 192
#define STM32_PLLI2SR_VALUE                 5
#define STM32_BKPRAM_ENABLE                 FALSE
#endif /* MCUCONF_H */
main.cpp
#include "ch.hpp"
#include "usbcfg.h"
#include "chprintf.h"
using namespace chibios_rt;
#define cls(chp)  chprintf(chp, "\033[2J\033[1;1H")
 * Application entry point.
uint16_t channels[16];
bool failSafe;
bool lostFrame;
int main(void) {
   * System initializations.
   *   RTOS is active.
  System::init();
  /* Initializes a serial-over-USB CDC driver.*/
  sduObjectInit(&SDU1);
  sduStart(&SDU1, &serusbcfg);
  BaseSequentialStream * chp = (BaseSequentialStream *)&SDU1;
   * Activates the USB driver and then the USB bus pull-up on D+.
   * Note, a delay is inserted in order to not have to disconnect the cable
   * after a reset.
  chThdSleepMilliseconds(1500);
  int i = 0;
    /* Normal main() thread activity, printing MEMS data on the SDU1.*/
  while (true) {
    palClearPad(GPIOG, 15);
    chprintf(chp,"workling : %d ", i++);
    chThdSleepMilliseconds(500);
    palSetPad(GPIOG, 15U);
    cls(chp);
  return 0;
My guess is something in mcuconf because there is not too much other place where I can screw it but Clock48 is required and Cube and build looks satisified with settings.
Has thanked: 1146 times
Been thanked: 960 times
Re: Another CDC/USB issue - 407ZGT6 minimum board
Postby Giovanni » Tue Mar 17, 2020 9:32 am
Does the host enumerate the device or is it silentl? is the enumeration at least triggered?
Anyway, the problem can be in GPIO settings or clocks, you need to verify those, the driver itself works on a lot of boards.
AmperCZ
Postby AmperCZ » Tue Mar 17, 2020 10:33 am
Failed during enumeration, Windows see unknown device and says that stopped it due issues , code 43.
So my guess is more likely clock issue than pins, I will try to hookup oscilloscope on A11/A12 to check clock.
Postby Giovanni » Tue Mar 17, 2020 11:42 am
No external PHY, right? if so then I agree with a clock issue.
AmperCZ
Postby AmperCZ » Tue Mar 17, 2020 6:07 pm
So I used scope and what I see is
20ms wait is exactly 20ms
I can see couple of KJ pairs running on USB immediatelly after I connect cable with about 1mS time between them
I belive that for USB 48M clocks on 25M crystal is required this (I cut out only what is connected to usb by my knowledge)
I am on the end with my knowledge, everything looks ok (so it must be something super simple what I am overlooking :-D )
Is here enyone who have 407 board with 25Mhz crystal and workling USB CDC who can share board.h/mcuconf.h ?
Postby Giovanni » Tue Mar 17, 2020 7:16 pm
OLIMEX_STM32_P407 has a 25MHz clock, anyway, the only difference is PLLM, all the other values should be the same on any 407.
AmperCZ
Postby AmperCZ » Tue Mar 17, 2020 8:28 pm
well, now it starts to be funny - it is working now. I took working Disco mcuconf.h and used it on new board.
Difference which make issue is LSE
Even with RTCSEL on LSI it stops working right immediatelly after I change this to true. Board have external 32k osc connected to osc32 so that was reason why I used it. Never hit info that LSE is not compatible with USB or what will happen if LSE is active and 32k osc is in trouble (it is still cheap board). Needles to say is that I am using 18.2 OS version
Postby Giovanni » Tue Mar 17, 2020 9:28 pm
LSE should not have any impact, do you have another board to try?
Please update to 20.3.0 (release tomorrow), 18.2 is going out of maintenance.
AmperCZ
Postby AmperCZ » Wed Mar 18, 2020 7:17 am
Second board of same kind have same result, Disco don't have LSE mounted and that's all what I currently have in 407 range :-(
Will update and check result later today
AmperCZ
Postby AmperCZ » Wed Mar 18, 2020 12:46 pm
Updated to 20.3 and situation is same - LSE activation breaks USB CDC
Return to “STM32 Support”
Users browsing this forum: No registered users and 105 guests
