Memory-mapped flash on F7 and H7
Has thanked: 1076 times
Been thanked: 922 times
Re: Memory-mapped flash on F7 and H7
Postby Giovanni » Sat Feb 20, 2021 8:36 pm
I took it from the F7 code.
RCC_AHB3ENR_QSPIEN | RCC_AHB3RSTR_QSPIRST
Note that you are mixing constants of 2 different registers here.
andypiper
Has thanked: 5 times
Been thanked: 4 times
Postby andypiper » Sat Feb 20, 2021 10:00 pm
Giovanni wrote:I took it from the F7 code.
I wondered about that, but isn't this the same?
  rccResetAHB4(~(RCC_APB4RSTR_SYSCFGRST | STM32_GPIO_EN_MASK));
Postby Giovanni » Sat Feb 20, 2021 10:29 pm
STM32_GPIO_EN_MASK is used for both enabling and resetting, it relies on registers having bits in same position. If you use ST header definitions then better use the correct ones.
andypiper
Postby andypiper » Sun May 16, 2021 4:31 pm
I've started on this again, but using a Nucleo H743 board with a breakout so that I can debug. The flash chip I want to support is W25Q128JV is this the same chip as supported by the N25Q serial nor driver? Or do I have to write my own?
The reason I ask is the driver hangs in snorStart() for me.
Postby Giovanni » Sun May 16, 2021 4:53 pm
It is different, a new mini-driver is required.
andypiper
Postby andypiper » Tue May 18, 2021 8:06 am
Giovanni wrote:Hi,
Hi so I have written the mini driver. Now I see that I am missing the wiring of the QUADSPI pin functions into the driver. I am struggling to find an example of how to set this up, can you point me at it? I would have thought it would go in here
const WSPIConfig WSPIcfg1 = {
.end_cb = NULL,
.error_cb = NULL,
.dcr = STM32_DCR_FSIZE(24U) | /* 16MB device. */
STM32_DCR_CSHT(1U) /* NCS 2 cycles delay. */
but doesn't seem to be
andy
Postby Giovanni » Tue May 18, 2021 9:06 am
Sorry, I don't understand your question.
andypiper
Postby andypiper » Tue May 18, 2021 9:53 am
Giovanni wrote:Sorry, I don't understand your question.
On the H7 there are certain pins that can be mapped to QUADSPI - how do I specify which pins those are to the wspi driver? There are at least two possibilities on H7
steved
Has thanked: 12 times
Been thanked: 135 times
Postby steved » Tue May 18, 2021 1:07 pm
Your driver talks to the WSPI peripheral, which is a fixed entity (OK, maybe there are two, as with serial ports, but same principle).
The board setup file then links the required pins with the WSPI peripheral.
andypiper
Postby andypiper » Tue May 18, 2021 1:14 pm
steved wrote:Your driver talks to the WSPI peripheral, which is a fixed entity (OK, maybe there are two, as with serial ports, but same principle).
Its the board setup file I am missing in this case - can you point me at an example?
Return to “STM32 Support”
