stm32h743vit6 demo
Amir1980
stm32h743vit6 demo
Postby Amir1980 » Sun Jan 22, 2023 8:27 am
I am working on my custom board with stm32h743vit6 MCU, I have seen a demo project for stm32h743, RT-STM32H743ZI_REV_XY-NUCLEO144, I have a copy of this project renamed to a new name, made some changes to the config files, the only needed peripherals are an UART (UART5 pins: PC12 and PD2) and a LED (pin: PA7) for blinking. it's all I need to start my chibios learning.
the NUCLEO H743 has a 144pin stm32h743zi, my board has a 100pin h743vit6, I have no idea how to change current config files, I have made some changes but no success blinking LED, please have a look at my config files and let me know if there are other changes needed to make it work.
my debugger is a st-link v2 and st_nucleo_h743zi.cfg file with openocd.
here is the result when start debug:
Info : Listening on port 6666 for tcl connections
Info : Listening on port 4444 for telnet connections
Info : clock speed 2000 kHz
Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Info : STLINK V2J40M27 (API v2) VID:PID 0483:374B
Info : Target voltage: 3.245204
Info : stm32h7x.cpu0: Cortex-M7 r1p1 processor detected
Info : stm32h7x.cpu0: target has 8 breakpoints, 4 watchpoints
Info : starting gdb server for stm32h7x.cpu0 on 3333
Info : Listening on port 3333 for gdb connections
Info : accepting 'gdb' connection on tcp/3333
target halted due to debug-request, current mode: Thread
xPSR: 0x21000000 pc: 0x08001724 psp: 0x200007e0
Info : Device: STM32H74x/75x
Info : flash size probed value 2048k
Info : STM32H7 flash has dual banks
Info : Bank (0) size is 1024 kb, base address is 0x08000000
Warn : Prefer GDB command "target extended-remote :3333" instead of "target remote :3333"
xPSR: 0x01000000 pc: 0x08000378 msp: 0x20000400
invalid command name "erase_address"
the main.c file:
#include "ch.h"
#include "rt_test_root.h"
#include "oslib_test_root.h"
#include "chprintf.h"
 * This is a periodic thread that does absolutely nothing except flashing
 * a LED.
  (void)arg;
  while (true) {
    palSetLine(LINE_myLED1);
    chThdSleepMilliseconds(500);
    palClearLine(LINE_myLED1);
 * Application entry point.
int main(void) {
   * System initializations.
   *   RTOS is active.
  //sdStart(&SD3, NULL);
  //sdStart(&SD5, NULL);
   * Creates the example thread.
  chThdCreateStatic(waThread1, sizeof(waThread1), NORMALPRIO+1, Thread1, NULL);
   * sleeping in a loop and check the button state.
  while (1) {
    /*if (palReadLine(LINE_BUTTON)) {
      test_execute((BaseSequentialStream *)&SD5, &rt_test_suite);
      test_execute((BaseSequentialStream *)&SD5, &oslib_test_suite);
Regards,
Amir.
board.zip
(10.23 KiB) Downloaded 80 times
conf-files.zip
(11.21 KiB) Downloaded 80 times
Re: stm32h743vit6 demo
Postby Giovanni » Sun Jan 22, 2023 9:25 am
Board files are generated, you should not edit them manually, note the "cfg" directory under the various boards, there is an XML file in there to edit.
This is a video about editing board files, hope it can help: https://www.youtube.com/watch?v=HwJqZfITvV0
Are you using ChibiStudio? the generator of board files is included there, alternatively you can use this script /os/hal/boards/genboard.sh, it requires the installation of the FMPP tool.
About OpenOCD, are you able to reach the main() and step from there?
Amir1980
Postby Amir1980 » Sun Jan 22, 2023 10:23 am
Dear Giovanni,
Thanks for the reply. Yes, I am using chibistudio, I wish to use keil with chibios and its hal libraries, but I don't know how to use it with keil. I have not tried yet.
about the openOCD, I guess it stuck in halInit.
if you mean board.chcfg by xml file, yes, I have modified it too, but didn't use genboard to regenerate it. I will try and reply.
Regards,
Amir.
Postby Giovanni » Sun Jan 22, 2023 10:32 am
Make sure to look at the ChibiStudio guides on http://www.playembedded.org most topics are covered there.
Amir1980
Postby Amir1980 » Sun Jan 22, 2023 4:51 pm
Info : clock speed 1000 kHz
Info : Target voltage: 3.246781
Info : Bank (1) size is 1024 kb, base address is 0x08100000
xPSR: 0x21000000 pc: 0x08001722 psp: 0x200007e0
Info : Padding image section 0 at 0x080021b0 with 16 bytes (bank write end alignment)
Info : dropped 'gdb' connection (error -400)
here is the result of program and debug after regenerating xml file using genboard.sh.
it seems there is a problem with debugging.
is it okay to use st_nucleo_h743zi.cfg file for stm32h743vit6?
Regards,
Amir.
Postby Giovanni » Sun Jan 22, 2023 5:05 pm
I launch OpenOCD from ChibiStudio using "OpenOCD on STLink (prompts for .cfg target configuration)".
Then I select /openocd/scripts/target/stm32h7x.cfg or /openocd/scripts/target/stm32h7x_dual.cfg depending on device.
This is board-independent.
Amir1980
Postby Amir1980 » Mon Jan 23, 2023 10:40 am
Dear Giovanni,
Thanks, I have found the problem, it was using LSE by default which I don't use, switched to LSI, its working now.
Thanks for your support.
Regards,
Amir.
Return to “STM32 Support”
Users browsing this forum: No registered users and 15 guests
