I have to read data from a BMP180 sensor, it's on my custom board, PD12,PD13 pins, I2C4. how to use i2cDriver? how to config i2cv3?
I didn't found any H7 i2c example.
Regards,
Amir.
STM32H743 I2C
- Has thanked: 1074 times
- Been thanked: 921 times
Re: STM32H743 I2C
Look of other I2C examples, API is the same. You could try to ask on the Discord server, probably somebody already used it on h7.
Re: STM32H743 I2C
Dear Giovanni,
I didn't found any example using i2c on H7 device, the problem is not the i2cDriver, my problem is the i2c config:
the compiler replied: main.c:59:7: error: 'OPMODE_I2C' undeclared here (not in a function)
and main.c:61:7: error: 'STD_DUTY_CYCLE' undeclared here (not in a function)
Regards,
Amir.
static const I2CConfig i2cConfig = {
OPMODE_I2C,
100000,
STD_DUTY_CYCLE,
Regards,
Amir.
Re: STM32H743 I2C
That configuration structure is for I2Cv1, the I2Cv2/I2Cv3 structure is different:
Note that those are register values, the documentation is on the STM32 reference manual, especially "TIMINGR" is critical. Values can be written as numeric constant or using ST-defined macros present in the STM32 CMSIS header for your device, see under /os/common/ext/ST and pick yours.
struct hal_i2c_config {
* @brief TIMINGR register initialization.
* @note Refer to the STM32 reference manual, the values are affected
* by the system clock settings in mcuconf.h.
uint32_t timingr;
* @brief CR1 register initialization.
* @note Leave to zero unless you know what you are doing.
uint32_t cr1;
* @brief CR2 register initialization.
* @note Only the ADD10 bit can eventually be specified here.
uint32_t cr2;
Users browsing this forum: No registered users and 15 guests
