STM32H750 not booting
elpekenin
Re: STM32H750 not booting
Postby elpekenin » Mon Jul 31, 2023 4:47 pm
I just found out why it crashed... It's because tu2 was doing:
  • Init QSPI in mem-mapped mode
  • Check if we should jump to user code and do so if appropriate. I will later try and find out whether this config is keep or we need to re-config it...
  • if no jump, re-inits the QSPI bus without mem-mapping (apparently author couldnt get it working by just exiting mapped mode). This is to be able to write on the QSPI flash the file received over USB, i guess (as mem-mapped is read-only)
  • After this, my code tried reading as mem-mapped, obviously failed :lol:. I could get it to read from 0x90000000 by going into the mode again
So i "just" need to figure out why it is either:
  • Not detecting the code on QSPI as bootable and jumping to it (pretty sure this is what happens)
  • Crashing when user code (ChibiOS) runs and falling back to bootloader (not sure if that's even the behaviour on crash)
elpekenin
Postby elpekenin » Fri Aug 04, 2023 4:38 pm
Good news, i can jump into the uf2 now. Had to use the erase-firmware "app" first, to get the "is app valid?" check to pass, probably a little bug somewhere.
Bad news, it breaks early on init
According to STLink, program halts...
__STATIC_INLINE void __rccResetAHB4(uint32_t mask) {
  /* Resetting the peripherals.*/
  RCC->AHB4RSTR |= mask;
  RCC->AHB4RSTR &= ~mask; // << HERE
  (void)RCC->AHB4RSTR;
With call stack being (some weirdness as this is QMK, and not "vanilla" ChibiOS)
__rccResetAHB4
stm32_gpio_init
__chibios_override___early_init
__early_init
However, as far as i can tell from RefManual, this register doesnt affect the QSPI peripheral. That would be problematic since the .uf2 gets loaded in the QSPI flash, and code would have to send a (sequence?) command to put the flash on MemoryMapped mode....
My understanding is that, since tinyuf2 is managing QSPI before jumping into ChibiOS, i wouldn't need any QSPI configuration (not even enable it on HAL) and code would transparently read addresses on the 0x9000_0000 range as it is already working as desired. Am i mis-understanding anything?
Has thanked: 1078 times
Postby Giovanni » Fri Aug 04, 2023 5:18 pm
ChibiOS resets all peripherals on halInit() so any OSPI setting done before that call is undone internally, you need to perform halInit() before any other peripheral-related initialization.
elpekenin
Postby elpekenin » Sat Aug 05, 2023 2:16 pm
Tried adapting from testhal/STM32/multi/WSPI-MFS, however, even tho i added this (is itwrong? im a mk noob) to my QMK's board.mk file
include $(CHIBIOS)/os/hal/lib/complex/serial_nor/devices/micron_n25q/hal_flash_device.mk
I can't get my code past
Compiling: platforms/chibios/boards/WEACT_STM32_H750VBT6/board/extra.c                             platforms/chibios/boards/WEACT_STM32_H750VBT6/board/extra.c:7:10: fatal error: hal_serial_nor.h: No such file or directory
    7 | #include "hal_serial_nor.h"
compilation terminated.
Anyway, even if i got this to compile i would have 2 issues:
  • My hardware is W25Q64, im guessing i would need to write a specific driver
  • Some function would need a __attribute__((section(<RAM>))), because code would stop working (program counter would point at an unreachable address) as soon as QSPI peripheral is shut down, right? No idea which one that would be :|
After this, i've also tried some combinations of
  • Commenting out part of the init code
  • Changing the GPIO mask used on init, to value 0
  • Adding #define STM32_QSPI_NO_RESET
  • Setting #define STM32_NO_INIT TRUE
Of course, with no avail
Return to “STM32 Support”
