I have Ethernet and uSD card on one of my boards.
There seems to be a conflict between these two. I can either get Ethernet to work or MMC, but not both.
I found some information online that said Ethernet RAM has to start at 0x24000000, and my tests confirm that.
I can't mount the SD card, unless I comment out macInit() in hal.c and lwipInit() in my ethernet initialization code.
I'm using MMCD1 on SPI3.
MMC - Ethernet conflict H735 Topic is solved
Re: MMC - Ethernet conflict H735
Well seems like the issue is cache management.
My ram layout:
Once I modified STM32_NOCACHE_RASR from 16K to 128K I got both SD card and Ethernet working:
While the SD card mounts and I can successfully send ethernet packets, the whole thing crashes after a minute and ends in a _unhandled_exception. So while it's closer it's still not fully working
My ram layout:
ram0 (wx) : org = 0x24000000, len = 16k /* AXI SRAM no-cache*/
ram1 (wx) : org = 0x24004000, len = 304k /* AXI SRAM cached */
ram2 (wx) : org = 0x30000000, len = 32k /* AHB SRAM1 + SRAM2 */
ram3 (wx) : org = 0x30004000, len = 16k /* AHB SRAM2 */
ram4 (wx) : org = 0x38000000, len = 16k /* AHB SRAM4 */
ram5 (wx) : org = 0x20000000, len = 128k /* DTCM-RAM */
ram6 (wx) : org = 0x00000000, len = 64k /* ITCM-RAM */
ram7 (wx) : org = 0x38800000, len = 4k /* BCKP SRAM */
/* RAM region to be used for data segment.*/
REGION_ALIAS("DATA_RAM", ram1);
REGION_ALIAS("DATA_RAM_LMA", flash0);
/* RAM region to be used for BSS segment.*/
REGION_ALIAS("BSS_RAM", ram1);
/* RAM region to be used for the default heap.*/
REGION_ALIAS("HEAP_RAM", ram1);
/* RAM region to be used for nocache segment.*/
REGION_ALIAS("NOCACHE_RAM", ram0);
/* RAM region to be used for eth segment.*/
REGION_ALIAS("ETH_RAM", ram0);
* Memory attributes settings.
#define STM32_NOCACHE_ENABLE TRUE
#define STM32_NOCACHE_MPU_REGION MPU_REGION_6
#define STM32_NOCACHE_RBAR 0x24000000U
#define STM32_NOCACHE_RASR MPU_RASR_SIZE_128K
- Has thanked: 1078 times
