NUCLEO-L4R5ZI OTG Support
Tabulous
Has thanked: 7 times
Been thanked: 17 times
Postby Tabulous » Fri Nov 08, 2024 12:15 pm
Hi
having looked at the demo, wondering why the NUCLEO-L4R5ZI demo did not implement OTG test app like alot of the demos do ?
Is OTG supported on STM32L4R5ZI ?
Has thanked: 1097 times
Been thanked: 934 times
Re: NUCLEO-L4R5ZI OTG Support
Postby Giovanni » Fri Nov 08, 2024 1:06 pm
It is supported by the demo under /testhal/STM32/multi/USB_CDC
Tabulous
Postby Tabulous » Fri Nov 15, 2024 5:11 pm
So i'm running up the
RT-STM32L4R5ZI-NUCLEO144 example
using target\stm32l4x.cfg for the ST-LINK
It runs but the debugging seems flakey, does not run and stop at main as it is setup to, it stops nvicInit() ??
Tabulous
Postby Tabulous » Fri Nov 15, 2024 5:16 pm
I've fixed it, need to set optimization to -O0
Postby Giovanni » Fri Nov 15, 2024 7:04 pm
This is quite common, you may also try -Og which is specific for debug.
Tabulous
Postby Tabulous » Tue Nov 19, 2024 12:08 pm
Using /testhal/STM32/multi/USB_CDC
it seems to be working, but for some reason when the shell first start and you press CR for promt you never see the shell start info
i.e. chprintf(chp, "ChibiOS/RT Shell" SHELL_NEWLINE_STR);
Postby Giovanni » Tue Nov 19, 2024 6:54 pm
It also happens withe USB driver, I think it is the host discarding incoming data if the virtual com port is not yet opened by any process. You may try putting a delay before spawning the shell and opening a terminal before the shell spawns.
Return to “STM32 Support”
