MIPS32 port
ChibiOS public support forum for topics related to the micro-controllers based on MIPS32 cores.
Dmytro
Re: MIPS32 port
Postby Dmytro » Sun Nov 11, 2012 5:12 pm
Hi MaBl,
mabl wrote:do you run the kernel test cases in qemu? If so, is there a documentation on how to get the serial output? What hardware does qemu simulate for serial?
Yes I did. QEMU is emulating i8250 serial device and the driver is available for chibi-mips-qemu.
You should launch qemu with -nographic option as I didn't try to cook a driver for VGA.
best regards,
-- dmytro
Dmytro
Re: MIPS32 port
Postby Dmytro » Sun Nov 11, 2012 5:16 pm
All the documentation for MIPS-QEMU is in the readme: https://github.com/niamster/ChibiOS/tre ... /MIPS-QEMU
mabl
Re: MIPS32 port
Postby mabl » Sun Nov 11, 2012 5:18 pm
Dmytro wrote:Hi MaBl,
Very interesting, probably this driver would also work for cortex m3 simulation and qemu, right? I'm thinking of adding automated testing of kernels to chibios...
Dmytro
Re: MIPS32 port
Postby Dmytro » Sun Nov 11, 2012 6:26 pm
Yep, that should work fine. You will just also need PIC i8259 driver which is also included in os/hal/platforms/MIPS-QEMU
etmatrix
Re: MIPS32 port
Postby etmatrix » Sun Nov 11, 2012 11:24 pm
Dmytro wrote:Hi, etmatrix,
first of all thanks for trying this =)
Hi, Dmytro
thank you for your work
Dmytro wrote:Hum, as far as I remember the toolchain at http://developer.mips.com/tools/compile ... toolchain/ is for x86.
Sure but x86_64.
Dmytro wrote:Unfortunately I didn't try too much to build complete image with xc32. I don't like it a lot ...
Do you know the project Pinguino32? In the svn repository there is a compiler mips-elf, has no dependencies with XC32 or C32, it compile for PIC32MX without problems.
Dmytro wrote:Anyway you have to change the way the linker script is provided to the linker:
Ok thank you, I will try.
Dmytro
Re: MIPS32 port
Postby Dmytro » Mon Nov 12, 2012 11:17 am
Hi etmatrix,
Sure but x86_64.
Oh, I didn't notice.
Anyway once I polish the usage of shadow registers I'll try to make the port toolchain-independant.
etmatrix wrote:Do you know the project Pinguino32? In the svn repository there is a compiler mips-elf, has no dependencies with XC32 or C32, it compile for PIC32MX without problems.
I heard about it but never looked inside. Thanks for the link I'll take a look.
Dmytro
Re: MIPS32 port
Postby Dmytro » Mon Nov 12, 2012 2:29 pm
From the first glance in pinguino for pic32 they use precompiled binaries. That's not what I want for chibios.
I would like to have a way to supply fuse configuration in an open way.
Dmytro
Re: MIPS32 port
Postby Dmytro » Sun Nov 18, 2012 4:08 pm
I've pushed some updates to mips-pic32mx branch: use shadow registers in ISRs and difinition of boot config registers w/o xc32 support.
This getting the port closer to be xc32-independant, though it still depends on some sources and headers from xc32 toolchain.
I'm going to rewrite most of them but I will copy some target-definition headers as rewriting thousands of lines of register definition is a stupid work. As far as I remember the license permits copying.
Regarding the usage of shadow registers - it definetely gives perfomance boost but not doubling it(sorry, no numbers this time - I have issues with ISP at home so writing these lines from my work place and I forgot to save the results ...)
I've also played with xc32 as a toolchain to build the firmware but the magic done by xc32's linker is too black for me.
Eventually I was able to build an ELF which looks good for me, but in the end it does not boot on target. Even in debug mode I can't trace what's going on there.
cheers,
-- dmytro
Dmytro
Re: MIPS32 port
Postby Dmytro » Sat Nov 24, 2012 4:58 pm
I've updated mips-pic32mx branch with following changes:
- completely get rid of xc-32 dependency
- implementation of vectored interrupts if no shadow registers supported
- few bugfixes and cleanups
I've still been trying to build the whole thing with xc-32 but still have some issues with the sections. Linker does not want to include .data section.
Please let me know if support of xc-32 is that important so I'll try harder ...
regards,
-- dmytro
etmatrix
Re: MIPS32 port
Postby etmatrix » Sat Nov 24, 2012 10:44 pm
Dmytro wrote:Please let me know if support of xc-32 is that important so I'll try harder ...
For me was only a simple test. I have used xc-32 because the alternative was compile a mips-gcc from source code.
Return to “MIPS32 Support”
