Makefile rule Topic is solved
tfAteba
Has thanked: 91 times
Been thanked: 50 times
Makefile rule
Post by tfAteba »
I use vim to edit my files, so it create me backup files such as main.c~ for example.
I saw that when running the command make clean, those file are not deleted.
Can we add a rule to the makefile to do that?
Theo.
Re: Makefile rule
I prefer for the makefile to delete only what it generated during a build, people could want to keep their backups.
You could add a new rule fullclean to your Makefile after the inclusion of rules.mk.
tfAteba
Re: Makefile rule
Post by tfAteba »
Ok, I understand ;). I will do that. I will also add the rule to flash my bord, like make program. So I don't have to write it every time I want to flash my MCU.
Theo.
barthess
Re: Makefile rule
Post by barthess »
@Theodore ATEBA
As Giovanni said it is not make's task. I use version control facilities for such job ("git clean -xdf" in my case).
SVN also able to clean working copy but I can not remember exact command.
tfAteba
Re: Makefile rule
Post by tfAteba »
Hi Barthess,
Good alternative to the Makefile rule to clean the working directory.
I'm used to Git so I can use this possibility. I don't know SVN but don't worry ;).
Thanks for the clue.
Theo
