chPoolAlloc fails system state check
elasticdoor
Has thanked: 2 times
Postby elasticdoor » Sun Nov 28, 2021 9:27 pm
I am building an application in which I need to allocate and free objects, so I thought I'd do this with a memory pool. The problem is that if I call chPoolAlloc when the runtime system state checks are active, the system halts when I try to instantiate a new object from the pool. If the system state checks are disabled, the program runs normally.
Here is some of my code
typedef struct cvg_block cvg_block_t;
struct cvg_block {
  cvg_block_t *next;
  uint32_t channel;
  uint16_t cv;
  uint8_t gate;
  uint8_t listeners;
  uint8_t read_count;
memory_pool_t cvg_block_mempool;
static THD_WORKING_AREA(testwa, 128);
THD_WORKING_AREA(waChainRoutine, 128);
THD_FUNCTION(ChainRoutine, arg) {
  cvg_block_t *b = (cvg_block_t *)chPoolAlloc(&cvg_block_mempool);
  while(true) {
void chSetup() {
  chPoolObjectInit(&cvg_block_mempool, sizeof(cvg_block_t), chCoreAllocAligned);
  chThdCreateStatic(testwa, sizeof(testwa), NORMALPRIO, ChainRoutine, NULL);
void setup() {
  chBegin(chSetup);
  /* chBegin should never return */
  while(true) {}
This is of course a simplification of the whole code, but I did my best to isolate what I think is the problem.
I am using the following library: https://github.com/greiman/ChRt which is an Arduino port of chibiOS. This is because the platform I'm using is the Teensy4.1. Moreover, because of hardware limitations of the Teensy, I am unable to connect a debugger and look at the panic message.
Any help is appreciated and thank you in advance!
Has thanked: 1074 times
Been thanked: 921 times
Re: chPoolAlloc fails system state check
Postby Giovanni » Sun Nov 28, 2021 9:35 pm
I don't see anything obviously wrong in that code (which is a customization, I don't know all the rework done there).
Without a stack trace is not possible to tell which check is failing, you really need a debugger. Note that the check failures could not be related to pools, it could be triggered by something else.
Return to “General Support”
Users browsing this forum: No registered users and 14 guests
