[READ] Common Questions & Answers
Moderators: tfAteba, barthess, RoccoMarco, lbednarz, utzig
Has thanked: 1112 times
Been thanked: 937 times
Postby Giovanni » Mon Aug 12, 2013 11:06 am
First a small premise, the support is given by volunteers, please try to find answers first by yourself by:
- Reading and Data Sheet and the Reference Manual for device-related questions.
- Reading the documentation and the articles available here:
http://www.chibios.org/dokuwiki/doku.ph ... tion:start
http://www.chibios.org/dokuwiki/doku.ph ... cles:start
http://wiki.chibios.org/dokuwiki/doku.p ... :documents
- Reading the community-contributed guides available here: http://wiki.chibios.org/dokuwiki/doku.p ... :community
- Searching the forum in order to see if your question has been already answered. It is better to search using Google and by restricting the result to this forum by adding: site:forum.chibios.org to your search query. The forum search does not function well.
If all the above fails then ask on the forum by giving as much information as possible, at very minimum:
1) Which platform, for example STM32F4xx.
2) ChibiOS version used.
3) Nature of the problem and effects.
For hard to debug problems it is a good idea to attach a small project, that would enable us to help with debugging. Keep the project *minimal*. Read this topic about submitting reports.
Various answered questions:
About Kernel
I lock state or S lock state?
Event not triggering
See also this contributed guide about events:
Events.zip
(115.9 KiB) Downloaded 943 times
Serial and UART drivers
Difference between UART and Serial driver
Events and Serial Driver
ADC
ADCConversionGroup in ChibiOS 2.6
DMA
SPI1 DMA already allocated
PAL
PAL differnce between PORT and PAD ?
PWM
Dynamic PWM channel configuration?
USB
Configuring the USB on the STM32L1xx
I2C
Generic troubleshooting guide
I2C No ack error
CAN
CAN Frames not received on STM3210C-EVAL
µGFX
External forum
To all moderators, please add useful support topics to this post.
Re: [READ] Common Questions & Answers
Postby Tectu » Mon Aug 12, 2013 12:32 pm
I added a link to forward all µGFX related question to the dedicated forum - Hope that helps. I also added the link to the I2C troubleshooting guide.
Maybe you want to make this post sticky?
Reason: spelling
ceremcem
Has thanked: 7 times
Been thanked: 6 times
Postby ceremcem » Mon Aug 10, 2015 7:00 am
First two links are broken.
Postby Giovanni » Mon Aug 10, 2015 7:57 am
Fixed thanks.
kimmoli
Has thanked: 11 times
Been thanked: 9 times
Postby kimmoli » Sat Nov 05, 2016 8:02 pm
The link to I2C Troubleshooting guide is dead:
http://www.chibios.org/dokuwiki/doku.ph ... e_shooting
Postby Giovanni » Sat Nov 05, 2016 8:47 pm
Fixed thanks.
enrico.dallavia
Postby enrico.dallavia » Wed Aug 26, 2020 5:03 pm
Good evening,
it seems that all the link are now broke again. I'm brought to a page non exists or a blank page. Could you please provide the correct address, if it is still available?
Many thanks.
Return to “General Support”
