Soft reset
rambo
Re: Soft reset
Postby rambo » Sat Sep 06, 2014 4:02 pm
@MarkusS
I end up in _unhandled_exception for some reason:
(gdb) break ResetHandler
Breakpoint 1 at 0x8001580: file ChibiOS/os/ports/GCC/ARMCMx/crt0.c, line 282.
(gdb) cont
Continuing.
Note: automatically using hardware breakpoints for read-only addresses.
Breakpoint 1, ResetHandler () at ChibiOS/os/ports/GCC/ARMCMx/crt0.c:282
282     uint32_t *magic_word =  (uint32_t *)(SYMVAL(__ram_end__) - 4); // look at the last word in ram
(gdb) step
283     if (*magic_word == 0xDEADBEEF) {
(gdb) step
373   }
(gdb) step
284         *magic_word = 0; // reset magic flag
(gdb) step
285         ((funcp_t) (*(uint32_t *)0x1FFF0004U))(); // jump into boot loader
(gdb) step
(gdb) step
(gdb) step
^C
Program received signal SIGINT, Interrupt.
_unhandled_exception () at ChibiOS/os/ports/GCC/ARMCMx/STM32F4xx/vectors.c:226
226   void _unhandled_exception(void) {
(gdb) bt
#0  _unhandled_exception ()
#1  <signal handler called>
#2  0x00000000 in ?? ()
#3  0x1fff3d2a in ?? ()
#4  0x1fff3d2a in ?? ()
(gdb)
ych
Has thanked: 7 times
Been thanked: 9 times
Re: Soft reset
Postby ych » Tue Mar 03, 2015 11:57 pm
MarkusS,
Thank you for your code examples, it helps :).
In the end I improve your example by moving changes which you made in os/ports/GCC/ARMCMx/crt0.c to board.c in __early_init function
void __early_init(void) {
  if (MAGIC_DATA_CHECK()) {
    MAGIC_DATA_CLEAN();
    __set_CONTROL(0);
    __set_MSP((*(uint32_t *)0x1FFF0000U)); // this constant taken from "Device-dependent bootloader parameters" section of AN2606
    ((void (*)(void)) (*(uint32_t *)0x1FFF0004U))();
  } else {
    stm32_clock_init();
and yes I init stack pointer (as described int video tutorial), because I have issue without it.
Korken
Has thanked: 5 times
Been thanked: 6 times
Re: Soft reset
Postby Korken » Thu Mar 26, 2015 8:45 pm
Did anyone get it working without using the magic during startup?
I've been trying to jump too the bootloader as well (after all deinit of ChibiOS and clocks), but the chip (STM32F405) just resets instead...
Also I've been searching the AN2606 why it resets, but I cannot find an explanation.
alex31
Has thanked: 38 times
Been thanked: 61 times
Re: Soft reset
Postby alex31 » Tue Jul 05, 2016 6:58 am
I occasionally use NVIC_SystemReset and it works for all my projects ... but one.
I have a project where NVIC_SystemReset, and even chibios watchdog don't do anything, the MCU (stm32F4, chibios 16.1.5) continue
to run after an explicit reset request or watchog counter reaching end.
Any idea before i begin the game of difference between the projects where it works and this one who think he is chuck norris ?
Alexandre
Has thanked: 1074 times
Been thanked: 921 times
Re: Soft reset
Postby Giovanni » Tue Jul 05, 2016 7:10 am
I cannot imagine a way to make a reset-resistant application even if I wish to do so...
alex31
Re: Soft reset
Postby alex31 » Tue Jul 05, 2016 8:20 am
got it.
I was running on debugger (black magic probe, master branch) , and for an unknown reason, the bmp maintain NRST pin at high level,
and this cancel software reset.
Alexandre
aGuegu
Been thanked: 5 times
Re: Soft reset
Postby aGuegu » Mon Jan 01, 2018 4:54 pm
For STM32F103, coretx M-3 based chip,
void softreset(void) {
  *(uint32_t *)(0xE000ED0CUL) = 0x05FA0000UL | (*(uint32_t *)(0xE000ED0CUL) & 0x0700) | 0x04;
It is mainly the NVIC_SystemReset in core_cm3.h in stdperiph lib. Other cores have this function too.
According to RM0008, this software reset works same as the external NRST pin reset.
sabdulqadir
Has thanked: 13 times
Been thanked: 4 times
Re: Soft reset
Postby sabdulqadir » Thu Jun 10, 2021 1:08 am
Giovanni wrote:Hi,
It depends :-)
There is procedure to shutdown entirely the OS, it is described in this article: http://www.chibios.org/dokuwiki/doku.ph ... os:stop_os
If you have threads performing critical operations like writes in EEPROM or Flash then you may want to safely stop the threads then perform the reset.
Can you update the link?
Thanks,
AQ
Return to “General Support”
Users browsing this forum: No registered users and 16 guests
