STM32L4R5ZI-NUCLEO144: How to activate the I2C4 bus on mcuconf.h?
Moderators: utzig, lbednarz, tfAteba, barthess, RoccoMarco
sntnjrg
Has thanked: 18 times
Re: STM32L4R5ZI-NUCLEO144: How to activate the I2C4 bus on mcuconf.h?
Postby sntnjrg » Wed Aug 26, 2020 11:58 am
I compile the demo with last version and it is working. The only difference I see is the chconf.h file. If I add these changes to this file, the demo will generate the same compilation error:
  *          of ticks that is safe to specify in a timeout directive.
  *          The value one is not valid, timeouts are rounded up to
  *          this value.
 #if !defined(CH_CFG_ST_TIMEDELTA)
 #define CH_CFG_ST_TIMEDELTA                 2
-#define CH_CFG_ST_TIMEDELTA                 0
@@ -318,14 +315,11 @@
  * @note    The default is @p TRUE.
  * @note    Requires @p CH_CFG_USE_WAITEXIT.
  * @note    Requires @p CH_CFG_USE_HEAP and/or @p CH_CFG_USE_MEMPOOLS.
 #if !defined(CH_CFG_USE_DYNAMIC)
 #define CH_CFG_USE_DYNAMIC                  TRUE
-#define CH_CFG_USE_DYNAMIC                  FALSE
@@ -537,42 +531,33 @@
  * @brief   Debug option, kernel statistics.
  * @note    The default is @p FALSE.
 #if !defined(CH_DBG_STATISTICS)
 #define CH_DBG_STATISTICS                   FALSE
-#define CH_DBG_STATISTICS                   TRUE
  * @brief   Debug option, system state check.
  * @details If enabled the correct call protocol for system APIs is checked
  *          at runtime.
 #if !defined(CH_DBG_SYSTEM_STATE_CHECK)
 #define CH_DBG_SYSTEM_STATE_CHECK           FALSE
-#define CH_DBG_SYSTEM_STATE_CHECK           TRUE
  * @brief   Debug option, parameters checks.
  * @details If enabled then the checks on the API functions input
  *          parameters are activated.
 #if !defined(CH_DBG_ENABLE_CHECKS)
 #define CH_DBG_ENABLE_CHECKS                FALSE
-#define CH_DBG_ENABLE_CHECKS                TRUE
  * @brief   Debug option, consistency checks.
  * @details If enabled then all the assertions in the kernel code are
@@ -580,14 +565,11 @@
  *          runtime anomalies and port-defined checks.
 #if !defined(CH_DBG_ENABLE_ASSERTS)
 #define CH_DBG_ENABLE_ASSERTS               FALSE
-#define CH_DBG_ENABLE_ASSERTS               TRUE
  * @brief   Debug option, trace buffer.
  * @details If enabled then the trace buffer is activated.
@@ -628,14 +610,11 @@
  *          runtime measurement of the used stack.
 #if !defined(CH_DBG_FILL_THREADS)
 #define CH_DBG_FILL_THREADS                 FALSE
-#define CH_DBG_FILL_THREADS                 TRUE
  * @brief   Debug option, threads profiling.
  * @details If enabled then a field is added to the @p thread_t structure that
@@ -644,14 +623,11 @@
  * @note    This debug option is not currently compatible with the
  *          tickless mode.
 #if !defined(CH_DBG_THREADS_PROFILING)
 #define CH_DBG_THREADS_PROFILING            FALSE
-#define CH_DBG_THREADS_PROFILING            TRUE
Has thanked: 861 times
Been thanked: 743 times
Postby Giovanni » Wed Aug 26, 2020 1:38 pm
Do you have a custom linker script in your project? if so then start from one in the new version, some symbol names changed.
Return to “General Support”
