ChibiOS linking problem for printf
Rakibul007
Postby Rakibul007 » Thu Oct 29, 2020 10:50 pm
I'm using a very simple program to print something using UART2. Although the code is compiling, it is throwing me the following error. I'm using STM32F410RB Nucleo 64. I'm a total newbie in ChibiOS.
#include "hal.h"
#include "ch.h"
#include <stdio.h>
#ifdef __GNUC__
#define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
#define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
PUTCHAR_PROTOTYPE
  sdWrite(&SD2, (uint8_t *)&ch, 0xFFFF);
  return ch;
/* Serial configuration. */
static const SerialConfig myserialcfg = {
  115200,
  0,
  USART_CR2_STOP1_BITS,
  0
int main(void)
  sdStart(&SD2, &myserialcfg);
  int a = 1;
  while(1){
    printf("Hello - %d\n",a);
    a++;
    chThdSleepMilliseconds(1000);
Linking build/ch.elf
c:/chibistudio/tools/gnu tools arm embedded/9.0 2019q4/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: c:/chibistudio/tools/gnu tools arm embedded/9.0 2019q4/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/nofp\libg.a(lib_a-sbrkr.o): in function `_sbrk_r':
sbrkr.c:(.text._sbrk_r+0xc): undefined reference to `_sbrk'
c:/chibistudio/tools/gnu tools arm embedded/9.0 2019q4/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: c:/chibistudio/tools/gnu tools arm embedded/9.0 2019q4/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/nofp\libg.a(lib_a-writer.o): in function `_write_r':
writer.c:(.text._write_r+0x14): undefined reference to `_write'
c:/chibistudio/tools/gnu tools arm embedded/9.0 2019q4/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: c:/chibistudio/tools/gnu tools arm embedded/9.0 2019q4/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/nofp\libg.a(lib_a-closer.o): in function `_close_r':
closer.c:(.text._close_r+0xc): undefined reference to `_close'
c:/chibistudio/tools/gnu tools arm embedded/9.0 2019q4/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: c:/chibistudio/tools/gnu tools arm embedded/9.0 2019q4/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/nofp\libg.a(lib_a-fstatr.o): in function `_fstat_r':
fstatr.c:(.text._fstat_r+0x12): undefined reference to `_fstat'
c:/chibistudio/tools/gnu tools arm embedded/9.0 2019q4/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: c:/chibistudio/tools/gnu tools arm embedded/9.0 2019q4/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/nofp\libg.a(lib_a-isattyr.o): in function `_isatty_r':
isattyr.c:(.text._isatty_r+0xc): undefined reference to `_isatty'
c:/chibistudio/tools/gnu tools arm embedded/9.0 2019q4/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: c:/chibistudio/tools/gnu tools arm embedded/9.0 2019q4/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/nofp\libg.a(lib_a-lseekr.o): in function `_lseek_r':
lseekr.c:(.text._lseek_r+0x14): undefined reference to `_lseek'
c:/chibistudio/tools/gnu tools arm embedded/9.0 2019q4/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: c:/chibistudio/tools/gnu tools arm embedded/9.0 2019q4/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m/nofp\libg.a(lib_a-readr.o): in function `_read_r':
readr.c:(.text._read_r+0x14): undefined reference to `_read'
make: *** [../../chibios203/os/common/startup/ARMCMx/compilers/GCC/mk/rules.mk:217: build/ch.elf] Error 1
"make -j24 all" terminated with exit code 2. Build might be incomplete.
Has thanked: 1076 times
Been thanked: 922 times
Re: ChibiOS linking problem for printf
Postby Giovanni » Fri Oct 30, 2020 8:53 am
There is a "syscalls.c" module to be included in makefile if you want to use the standard library, it is located under /os/various.
Rakibul007
Postby Rakibul007 » Fri Oct 30, 2020 4:07 pm
Thanks Giovanni. The code now compiles and creates the .elf file. However, it doesn't print anything in the Serial. I know about chprintf. So, I tried the following code -
#include "hal.h"
#include "ch.h"
#include <stdio.h>
#include <stdlib.h>
#include <stdarg.h>
#include <chprintf.h>
#ifdef __GNUC__
#else
PUTCHAR_PROTOTYPE
  return ch;
static BaseSequentialStream* chp = (BaseSequentialStream*) &SD2;
  115200,
  0,
  0
int main(void) {
  int a = 1;
  while(1){
    printf("Hello from printf- %d\n",a);
    a++;
    chprintf(chp,"Hello from chprintf - %d\n",a);
I get the result from chprintf (just to make sure that my Serial Driver is working), but nothing from the printf function. Do you have any idea what might cause this problem?
Postby Giovanni » Fri Oct 30, 2020 4:52 pm
No, you need to place a breakpoint in syscalls.c and see if printf() gets in there and data is written as expected.
Anyway, chprintf() is there exactly because the library is problematic to get to work and eats a lot of code space.
Rakibul007
Postby Rakibul007 » Fri Oct 30, 2020 5:25 pm
Sounds good. Thanks Giovanni for your support.
Return to “General Support”
Users browsing this forum: No registered users and 12 guests
