Hey!
I recently took a closer look at why the ChibiOS shell prompt would often not appear correctly on the USB virtual serial device, and wrote down the individual problems that I found, and solution I settled on:
https://michael.stapelberg.ch/posts/202 ... l-cdc-acm/
This issue was reproducible across platforms (ST32, KINETIS, MIMXRT1062), and the workaround works on Linux, macOS and Windows.
Perhaps this is something to apply to the other demos that use a USB virtual serial device, too?
Hope this helps a few people
FYI: ChibiOS shell on USB virtual serial (CDC ACM) on Linux needs a delay
- Has thanked: 4 times
- Been thanked: 3 times
Re: FYI: ChibiOS shell on USB virtual serial (CDC ACM) on Linux needs a delay
Good article, have you tried to exit the shell and see if it restarts? the semaphore is not necessarily signaled again.
Giovanni wrote:Hi,
Unfortunately, there’s another bug with exiting the shell (causes a hardfault) that I haven’t had time to look into. Until that one is fixed, I can’t test the restart scenario.
Does resetting the semaphore not signal all waiters? Is there a better way to use a semaphore, or perhaps a different primitive, in this case?
stapelberg wrote:Unfortunately, there’s another bug with exiting the shell (causes a hardfault) that I haven’t had time to look into.
Is the shell susystem initialized? (calling shellInit()).
What you could do is something like this:
forever
if USB is not active then
wait on the semaphore
end
spawn shell
wait shell
sleep a little bit
end
This way it waits on the semaphore if USB is not active, making sure it will be signaled on the next connection. Note that the Serial_USB driver has connect/disconnect events, you may try those too (CHN_CONNECTED, CHN_DISCONNECTED).
Users browsing this forum: No registered users and 45 guests
