Chibistudio Debug View RT3.x.x Topic is solved
rj-ae
Postby rj-ae » Wed Apr 06, 2022 4:23 pm
Hi all,
I am working with an application that is still using ChibiOS 3.0.5 and want to debug threading via ChibiStudio (I am using the most recent version). However, am I correct in concluding that I can only debug RT 6 and 7 with this version? In the debug view I can add a window for Debug View RT 3.x.x, but this throws an error as listed below. Is there another way to be able to debug RT3 similar to what is described here?
Thanks for taking the time in advance.
Remi
eclipse.buildId=4.15.0.I20200305-0155
java.version=11.0.14.1
java.vendor=Ubuntu
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Framework arguments:  -product org.eclipse.epp.package.java.product
Command-line arguments:  -data /home/remi/ChibiStudio/workspace_user -os linux -ws gtk -arch x86_64 -product org.eclipse.epp.package.java.product
org.eclipse.jface
Error
Wed Apr 06 17:12:08 CEST 2022
Unable to resolve plug-in "org.chibios.tools.eclipse.debug.chibiosrt3".
java.io.IOException: Unable to resolve plug-in "org.chibios.tools.eclipse.debug.chibiosrt3".
   at org.eclipse.core.internal.runtime.PlatformURLPluginConnection.parse(PlatformURLPluginConnection.java:64)
   at org.eclipse.core.internal.runtime.PlatformURLPluginConnection.resolve(PlatformURLPluginConnection.java:73)
   at org.eclipse.core.internal.boot.PlatformURLHandler.openConnection(PlatformURLHandler.java:69)
   at org.eclipse.osgi.internal.url.URLStreamHandlerProxy.openConnection(URLStreamHandlerProxy.java:123)
   at java.base/java.net.URL.openConnection(URL.java:1099)
   at org.eclipse.core.internal.runtime.PlatformURLConverter.toFileURL(PlatformURLConverter.java:34)
   at org.eclipse.core.runtime.FileLocator.toFileURL(FileLocator.java:261)
   at org.eclipse.jface.resource.URLImageDescriptor.getFilePath(URLImageDescriptor.java:232)
   at org.eclipse.jface.resource.URLImageDescriptor.access$2(URLImageDescriptor.java:220)
   at org.eclipse.jface.resource.URLImageDescriptor$URLImageFileNameProvider.getImagePath(URLImageDescriptor.java:57)
   at org.eclipse.swt.internal.DPIUtil.validateAndGetImagePathAtZoom(DPIUtil.java:422)
   at org.eclipse.swt.graphics.Image.<init>(Image.java:657)
   at org.eclipse.jface.resource.URLImageDescriptor.createImage(URLImageDescriptor.java:263)
   at org.eclipse.jface.resource.ImageDescriptor.createResource(ImageDescriptor.java:204)
   at org.eclipse.jface.resource.DeviceResourceManager.allocate(DeviceResourceManager.java:55)
   at org.eclipse.jface.resource.AbstractResourceManager.create(AbstractResourceManager.java:88)
   at org.eclipse.jface.resource.ResourceManager.createImageWithDefault(ResourceManager.java:195)
   at org.eclipse.jface.resource.ImageRegistry.get(ImageRegistry.java:206)
   at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.getImageFromURI(SWTPartRenderer.java:219)
   at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.getImage(SWTPartRenderer.java:229)
   at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.createTab(StackRenderer.java:880)
   at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.processContents(LazyStackRenderer.java:145)
   at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:676)
   at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:768)
   at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:739)
   at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:733)
   at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:45)
   at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:717)
   at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:71)
   at org.eclipse.e4.ui.workbench.renderers.swt.SashRenderer.processContents(SashRenderer.java:148)
   at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:51)
   at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:82)
   at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:105)
   at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:64)
   at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:680)
   at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:666)
   at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1086)
   at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
   at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1049)
   at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
   at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:658)
   at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:557)
   at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:154)
   at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:150)
   at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203)
   at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
   at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
   at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
   at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255)
   at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
   at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
   at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
   at java.base/java.lang.reflect.Method.invoke(Method.java:566)
   at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:657)
   at org.eclipse.equinox.launcher.Main.basicRun(Main.java:594)
   at org.eclipse.equinox.launcher.Main.run(Main.java:1447)
   at org.eclipse.equinox.launcher.Main.main(Main.java:1420)
Re: Chibistudio Debug View RT3.x.x  Topic is solved
Postby Giovanni » Thu Apr 07, 2022 7:56 am
The debug plugin for RT 3 is long unmaintained and has been removed.
Note that smart use of Eclipse "expressions" view allows to do exactly the same things that the plugin does, for example, try inspecting the global variable "ch", from there open the registry list and you can see all threads.
Said that, I strongly recommend to move to a recent release, RT3 is very old and known issues have not been fixed on that branch. After RT 3 API has not changed much.
Return to “General Support”
Users browsing this forum: No registered users and 54 guests
