palEnableLineEvent issue
Moderators: tfAteba, barthess, RoccoMarco, lbednarz, utzig
angainor
Been thanked: 2 times
Postby angainor » Tue Apr 04, 2023 10:09 pm
Hi, Giovanni,
I am having a hard time enabling an interrupt from an SPI device, which brings GPIOD_PIN2 low on my STM32F405. I have in my code:
        palEnableLineEvent(GPIOD_PIN2_SPI3_INT, PAL_EVENT_MODE_FALLING_EDGE);
        palSetLineCallback(GPIOD_PIN2_SPI3_INT, rfm22b_int_cb, NULL);
The device is an RFM22b transceiver. During the operation I enable the interrupts, but my callback is never called. I do check that the GPIO pin in question is initially high, then it is brought low by the device:
    rfm22b_data_ready = 0; // this is set to 1 in the callback
    chprintf(current_chp, "INT gpio pad is %d\r\n", palReadPad(GPIOD, GPIOD_PIN2_SPI3_INT));
    // Enable the transmitter.
    rfm22_write(RFM22_op_and_func_ctrl1, RFM22_opfc1_pllon | RFM22_opfc1_txon);
    // wait for end of transmission
    uint32_t cnt = 0;
    while(palReadPad(GPIOD, GPIOD_PIN2_SPI3_INT)) cnt++;
    chprintf(current_chp, "counter %d, data ready %d, INT gpio pad is %d\r\n", cnt, rfm22b_data_ready, palReadPad(GPIOD, GPIOD_PIN2_SPI3_INT));
The above prints the following output
INT gpio pad is 1
counter 50063, data ready 0, INT gpio pad is 0
So initially my GPIO pin is high, after 50k loop iterations it was brought down by the device, but the callback was not called.
I have used this method for another device, connected to another SPI bus, and it works correctly there. I really have no idea why it's not working in this case. Could you help out? Do you have any idea what I could be doing wrong?
Thanks!
Has thanked: 1132 times
Been thanked: 944 times
Re: palEnableLineEvent issue
Postby Giovanni » Wed Apr 05, 2023 3:00 am
Do you have other PAL callbacks? STM32 only allows for one callback for each port bit, for example you cannot have callbacks on both pins 5 of GPIOA and GPIOB.
Have you enabled assertions in chconf.h? is something caught? which version are you using?
angainor
Postby angainor » Wed Apr 05, 2023 6:18 am
Thanks for the answer!
I have another callback enabled on GPIOC_PIN4. That one works. I have now compiled the code with CH_DBG_ENABLE_ASSERTS. Nothing was printed to the serial console. I am using ChibiOS-ver21.11.3.
I can add some debug statements here and there, if you think it would help.
Postby Giovanni » Wed Apr 05, 2023 6:38 am
Assertions cause a system halt, nothing is printed, apparently not your case.
angainor
Postby angainor » Tue Apr 25, 2023 6:48 pm
FYI, this turned out to be my fault (of course). I used `palSetLineCallback` on a GPIO PAD definition. Curious though that this does not result in any compiler error. I didn't look too much at the code, but you do define `PAL_LINE` as a tuple of port and pad.
In any case, all works when I use it as intended ;)
m
Return to “General Support”
