/opt/local/lib/gcc/arm-none-eabi/13.2.0/../../../../arm-none-eabi/bin/ld: ./build/obj/hal_usb_lld.o (symbol from plugin): in function `Vector90':
(.text+0x0): multiple definition of `Vector90'; ./build/obj/hal_can_lld.o (symbol from plugin):(.text+0x0): first defined here
how to solve this issue.
the halconf.h is:
ChibiOS - Copyright (C) 2006..2020 Giovanni Di Sirio
* @file templates/halconf.h
* @brief HAL configuration header.
* @details HAL configuration file, this file allows to enable or disable the
* various device drivers from your application. You may also use
* this file in order to override the device drivers default settings.
* @addtogroup HAL_CONF
#ifndef HALCONF_H
#define HALCONF_H
#define _CHIBIOS_HAL_CONF_
#define _CHIBIOS_HAL_CONF_VER_8_4_
#include "mcuconf.h"
* @brief Enables the PAL subsystem.
#if !defined(HAL_USE_PAL) || defined(__DOXYGEN__)
#define HAL_USE_PAL TRUE
* @brief Enables the ADC subsystem.
#if !defined(HAL_USE_ADC) || defined(__DOXYGEN__)
#define HAL_USE_ADC FALSE
* @brief Enables the CAN subsystem.
#if !defined(HAL_USE_CAN) || defined(__DOXYGEN__)
#define HAL_USE_CAN TRUE
* @brief Enables the cryptographic subsystem.
#if !defined(HAL_USE_CRY) || defined(__DOXYGEN__)
#define HAL_USE_CRY FALSE
* @brief Enables the DAC subsystem.
#if !defined(HAL_USE_DAC) || defined(__DOXYGEN__)
#define HAL_USE_DAC FALSE
* @brief Enables the EFlash subsystem.
#if !defined(HAL_USE_EFL) || defined(__DOXYGEN__)
#define HAL_USE_EFL FALSE
* @brief Enables the GPT subsystem.
#if !defined(HAL_USE_GPT) || defined(__DOXYGEN__)
#define HAL_USE_GPT FALSE
* @brief Enables the I2C subsystem.
#if !defined(HAL_USE_I2C) || defined(__DOXYGEN__)
#define HAL_USE_I2C TRUE
* @brief Enables the I2S subsystem.
#if !defined(HAL_USE_I2S) || defined(__DOXYGEN__)
#define HAL_USE_I2S FALSE
* @brief Enables the ICU subsystem.
#if !defined(HAL_USE_ICU) || defined(__DOXYGEN__)
#define HAL_USE_ICU FALSE
* @brief Enables the MAC subsystem.
#if !defined(HAL_USE_MAC) || defined(__DOXYGEN__)
#define HAL_USE_MAC FALSE
* @brief Enables the MMC_SPI subsystem.
#if !defined(HAL_USE_MMC_SPI) || defined(__DOXYGEN__)
#define HAL_USE_MMC_SPI FALSE
* @brief Enables the PWM subsystem.
#if !defined(HAL_USE_PWM) || defined(__DOXYGEN__)
#define HAL_USE_PWM FALSE
* @brief Enables the RTC subsystem.
#if !defined(HAL_USE_RTC) || defined(__DOXYGEN__)
#define HAL_USE_RTC FALSE
* @brief Enables the SDC subsystem.
#if !defined(HAL_USE_SDC) || defined(__DOXYGEN__)
#define HAL_USE_SDC FALSE
* @brief Enables the SERIAL subsystem.
#if !defined(HAL_USE_SERIAL) || defined(__DOXYGEN__)
#define HAL_USE_SERIAL TRUE
* @brief Enables the SERIAL over USB subsystem.
#if !defined(HAL_USE_SERIAL_USB) || defined(__DOXYGEN__)
#define HAL_USE_SERIAL_USB TRUE
* @brief Enables the SIO subsystem.
#if !defined(HAL_USE_SIO) || defined(__DOXYGEN__)
#define HAL_USE_SIO FALSE
* @brief Enables the SPI subsystem.
#if !defined(HAL_USE_SPI) || defined(__DOXYGEN__)
#define HAL_USE_SPI FALSE
* @brief Enables the TRNG subsystem.
#if !defined(HAL_USE_TRNG) || defined(__DOXYGEN__)
#define HAL_USE_TRNG FALSE
* @brief Enables the UART subsystem.
#if !defined(HAL_USE_UART) || defined(__DOXYGEN__)
#define HAL_USE_UART FALSE
* @brief Enables the USB subsystem.
#if !defined(HAL_USE_USB) || defined(__DOXYGEN__)
#define HAL_USE_USB TRUE
* @brief Enables the WDG subsystem.
#if !defined(HAL_USE_WDG) || defined(__DOXYGEN__)
#define HAL_USE_WDG FALSE
* @brief Enables the WSPI subsystem.
#if !defined(HAL_USE_WSPI) || defined(__DOXYGEN__)
#define HAL_USE_WSPI FALSE
/* PAL driver related settings. */
* @brief Enables synchronous APIs.
* @note Disabling this option saves both code and data space.
#if !defined(PAL_USE_CALLBACKS) || defined(__DOXYGEN__)
#define PAL_USE_CALLBACKS FALSE
#if !defined(PAL_USE_WAIT) || defined(__DOXYGEN__)
#define PAL_USE_WAIT FALSE
/* ADC driver related settings. */
#if !defined(ADC_USE_WAIT) || defined(__DOXYGEN__)
#define ADC_USE_WAIT TRUE
* @brief Enables the @p adcAcquireBus() and @p adcReleaseBus() APIs.
#if !defined(ADC_USE_MUTUAL_EXCLUSION) || defined(__DOXYGEN__)
#define ADC_USE_MUTUAL_EXCLUSION TRUE
/* CAN driver related settings. */
* @brief Sleep mode related APIs inclusion switch.
#if !defined(CAN_USE_SLEEP_MODE) || defined(__DOXYGEN__)
#define CAN_USE_SLEEP_MODE FALSE
* @brief Enforces the driver to use direct callbacks rather than OSAL events.
#if !defined(CAN_ENFORCE_USE_CALLBACKS) || defined(__DOXYGEN__)
#define CAN_ENFORCE_USE_CALLBACKS FALSE
/* CRY driver related settings. */
* @brief Enables the SW fall-back of the cryptographic driver.
* @details When enabled, this option, activates a fall-back software
* implementation for algorithms not supported by the underlying
* hardware.
* @note Fall-back implementations may not be present for all algorithms.
#if !defined(HAL_CRY_USE_FALLBACK) || defined(__DOXYGEN__)
#define HAL_CRY_USE_FALLBACK FALSE
* @brief Makes the driver forcibly use the fall-back implementations.
#if !defined(HAL_CRY_ENFORCE_FALLBACK) || defined(__DOXYGEN__)
#define HAL_CRY_ENFORCE_FALLBACK FALSE
/* DAC driver related settings. */
#if !defined(DAC_USE_WAIT) || defined(__DOXYGEN__)
#define DAC_USE_WAIT TRUE
* @brief Enables the @p dacAcquireBus() and @p dacReleaseBus() APIs.
#if !defined(DAC_USE_MUTUAL_EXCLUSION) || defined(__DOXYGEN__)
#define DAC_USE_MUTUAL_EXCLUSION TRUE
/* I2C driver related settings. */
* @brief Enables the mutual exclusion APIs on the I2C bus.
#if !defined(I2C_USE_MUTUAL_EXCLUSION) || defined(__DOXYGEN__)
#define I2C_USE_MUTUAL_EXCLUSION TRUE
/* MAC driver related settings. */
* @brief Enables the zero-copy API.
#if !defined(MAC_USE_ZERO_COPY) || defined(__DOXYGEN__)
#define MAC_USE_ZERO_COPY FALSE
* @brief Enables an event sources for incoming packets.
#if !defined(MAC_USE_EVENTS) || defined(__DOXYGEN__)
#define MAC_USE_EVENTS TRUE
/* MMC_SPI driver related settings. */
* @brief Timeout before assuming a failure while waiting for card idle.
* @note Time is in milliseconds.
#if !defined(MMC_IDLE_TIMEOUT_MS) || defined(__DOXYGEN__)
#define MMC_IDLE_TIMEOUT_MS 1000
* @brief Mutual exclusion on the SPI bus.
#if !defined(MMC_USE_MUTUAL_EXCLUSION) || defined(__DOXYGEN__)
#define MMC_USE_MUTUAL_EXCLUSION TRUE
/* SDC driver related settings. */
* @brief Number of initialization attempts before rejecting the card.
* @note Attempts are performed at 10mS intervals.
#if !defined(SDC_INIT_RETRY) || defined(__DOXYGEN__)
#define SDC_INIT_RETRY 100
* @brief Include support for MMC cards.
* @note MMC support is not yet implemented so this option must be kept
* at @p FALSE.
#if !defined(SDC_MMC_SUPPORT) || defined(__DOXYGEN__)
#define SDC_MMC_SUPPORT FALSE
* @brief Delays insertions.
* @details If enabled this options inserts delays into the MMC waiting
* routines releasing some extra CPU time for the threads with
* lower priority, this may slow down the driver a bit however.
#if !defined(SDC_NICE_WAITING) || defined(__DOXYGEN__)
#define SDC_NICE_WAITING TRUE
* @brief OCR initialization constant for V20 cards.
#if !defined(SDC_INIT_OCR_V20) || defined(__DOXYGEN__)
#define SDC_INIT_OCR_V20 0x50FF8000U
* @brief OCR initialization constant for non-V20 cards.
#if !defined(SDC_INIT_OCR) || defined(__DOXYGEN__)
#define SDC_INIT_OCR 0x80100000U
/* SERIAL driver related settings. */
* @brief Default bit rate.
* @details Configuration parameter, this is the baud rate selected for the
* default configuration.
#if !defined(SERIAL_DEFAULT_BITRATE) || defined(__DOXYGEN__)
#define SERIAL_DEFAULT_BITRATE 115200
* @brief Serial buffers size.
* @details Configuration parameter, you can change the depth of the queue
* buffers depending on the requirements of your application.
* @note The default is 16 bytes for both the transmission and receive
* buffers.
#if !defined(SERIAL_BUFFERS_SIZE) || defined(__DOXYGEN__)
#define SERIAL_BUFFERS_SIZE 16
/* SIO driver related settings. */
#if !defined(SIO_DEFAULT_BITRATE) || defined(__DOXYGEN__)
#define SIO_DEFAULT_BITRATE 38400
* @brief Support for thread synchronization API.
#if !defined(SIO_USE_SYNCHRONIZATION) || defined(__DOXYGEN__)
#define SIO_USE_SYNCHRONIZATION TRUE
/* SERIAL_USB driver related setting. */
* @brief Serial over USB buffers size.
* @details Configuration parameter, the buffer size must be a multiple of
* the USB data endpoint maximum packet size.
* @note The default is 256 bytes for both the transmission and receive
* buffers.
#if !defined(SERIAL_USB_BUFFERS_SIZE) || defined(__DOXYGEN__)
#define SERIAL_USB_BUFFERS_SIZE 256
* @brief Serial over USB number of buffers.
* @note The default is 2 buffers.
#if !defined(SERIAL_USB_BUFFERS_NUMBER) || defined(__DOXYGEN__)
#define SERIAL_USB_BUFFERS_NUMBER 2
/* SPI driver related settings. */
#if !defined(SPI_USE_WAIT) || defined(__DOXYGEN__)
#define SPI_USE_WAIT TRUE
* @brief Inserts an assertion on function errors before returning.
#if !defined(SPI_USE_ASSERT_ON_ERROR) || defined(__DOXYGEN__)
#define SPI_USE_ASSERT_ON_ERROR TRUE
* @brief Enables the @p spiAcquireBus() and @p spiReleaseBus() APIs.
#if !defined(SPI_USE_MUTUAL_EXCLUSION) || defined(__DOXYGEN__)
#define SPI_USE_MUTUAL_EXCLUSION TRUE
* @brief Handling method for SPI CS line.
#if !defined(SPI_SELECT_MODE) || defined(__DOXYGEN__)
#define SPI_SELECT_MODE SPI_SELECT_MODE_PAD
/* UART driver related settings. */
#if !defined(UART_USE_WAIT) || defined(__DOXYGEN__)
#define UART_USE_WAIT FALSE
* @brief Enables the @p uartAcquireBus() and @p uartReleaseBus() APIs.
#if !defined(UART_USE_MUTUAL_EXCLUSION) || defined(__DOXYGEN__)
#define UART_USE_MUTUAL_EXCLUSION FALSE
/* USB driver related settings. */
#if !defined(USB_USE_WAIT) || defined(__DOXYGEN__)
#define USB_USE_WAIT FALSE
/* WSPI driver related settings. */
#if !defined(WSPI_USE_WAIT) || defined(__DOXYGEN__)
#define WSPI_USE_WAIT TRUE
* @brief Enables the @p wspiAcquireBus() and @p wspiReleaseBus() APIs.
#if !defined(WSPI_USE_MUTUAL_EXCLUSION) || defined(__DOXYGEN__)
#define WSPI_USE_MUTUAL_EXCLUSION TRUE
#endif /* HALCONF_H */
the mcuconf.h is:
#ifndef HALCONF_H
#define HALCONF_H
* hardware.
* at @p FALSE.
* buffers.
* buffers.
