starting openocd with debug launcher
Moderators: tfAteba, barthess, RoccoMarco, lbednarz, utzig
JessicaB
Postby JessicaB » Thu Nov 21, 2024 6:48 am
I'm new to ChibiOS and ChibiStudio/eclipse.
I'm using a ST-Link to debug. I want to click the Build/flash/run launcher and have it start OpenOCD. Currently I have to go to the external tools menu to find 'OpenOCD on STLink'. In addition, after clicking that I have to navigate to 'C:\ChibiStudio\tools\openocd\scripts\target\stm32f4x.cfg'. This is rather annoying. Can't the project remember which debugger and config I use?
steved
Has thanked: 12 times
Been thanked: 137 times
Re: starting openocd with debug launcher
Postby steved » Thu Nov 21, 2024 9:48 am
I just create a small batch file in the project directory which starts up openOCD in a project-specific way, such as:
REM starts in the Eclipse directory
cd ..\tools\openocd\
REM bin\openocd -s "scripts" -f board/st_nucleo_f7.cfg -l /Temp/Chibi/oocd.log -f add_rtos.cfg
bin\openocd -s "scripts" -f board/st_nucleo_f7.cfg -c "$_TARGETNAME configure -rtos chibios"
(The commented out statement adds console output to a log file, rather than displaying it).
Has thanked: 1111 times
Been thanked: 937 times
Postby Giovanni » Thu Nov 21, 2024 10:21 am
JessicaB wrote:I'm new to ChibiOS and ChibiStudio/eclipse.
You could "clone" the "OpenOCD on STLink" launcher and replace the prompt with a fixed path to a script.
1) External Tools Configuration... in the tools menu.
2) Select "OpenOCD on STLink" under "Programs".
3) Duplicate button and give the clone a better name.
4) In the arguments box replace "${file_prompt}" with your fixed path.
You can have as many launchers you want.
JessicaB
Postby JessicaB » Sat Nov 23, 2024 5:27 am
This made it easier.
Eclipse seems to be very configurable, and I think that makes it a bit confusing for beginners to change how it works from out of the box. I'm starting to get it.
Thanks for help!
Postby Giovanni » Sat Nov 23, 2024 8:36 am
True, Eclipse is confusing initially but then things start to make sense and it becomes very powerful.
Return to “General Support”
