Page 1 of 4
chThdSleepUntil() ??
Posted: Sat Feb 06, 2016 10:41 am
by RTOSman
Hello there,
i used this function chThdSleepUntil() instead chThdSleepMilliseconds(). my question is what is the value we use in chThdSleepUntil(). system tick or milliseconde??
and who tell the chThdSleepUntil() to begin to count ???
Re: chThdSleepUntil() ??
Posted: Mon Feb 08, 2016 12:57 am
by tfAteba
Hello RTOSman,
The value use for this function is tick. But if you want to use milliseconds as your reférence, then you have to make a conversion from (ms) to (tick) by using for exemple MS2ST() function.
I think, that the count begin at the moment you call your function, so you don't need to do anything else.
Theo.
Posted: Mon Feb 08, 2016 9:35 pm
by RTOSman
Thanks, and how about chVTGetSystemTime()) it return ticks or miliseconds ??
Posted: Mon Feb 08, 2016 9:55 pm
by tfAteba
chVTGetSystemTime() return the system ticks.
The function prototype is
static systime_t chVTGetSystemTime (void) and you can find all those informations on the ChibiOS/RT Manual
http://chibios.sourceforge.net/docs3/rt/group__time.html#ga9abde73a5b3e779d86bdec83ca57f028 It is well documented I think, so read that and if you have any other questions you are welcome.
Theo.
Posted: Mon Feb 08, 2016 11:08 pm
by RTOSman
Hello i read all the manual, but i still learning
. i have a problem with time i still can't master the time.
i have a thread i a high priority, it did this function
timeT = ST2MS(chVTGetSystemTime());
while (1)
ps_tel();//blink led suqar wave
chThdSleepUntil(MS2ST(timeT));
timeT += ST2MS(9);
over time my blink does'nt blink every 1 seconde !! why ?
Posted: Tue Feb 09, 2016 7:56 am
by tfAteba
Hi RTOSman,
You did a little mistake.
You want to blink your led every 1 second,
so why did you add ST2MS(9)?Want your thread to run every 1000ms, so :
- Just add 1000ms to timeT variable,
not ST2MS(9) - Then call chThdSleepUntil(MS2ST(timeT));
As a result:
while (1)
timeT += 1000;
And I don't understand why you convert and reconvert system time to ms and so on?
Take a look at this
http://www.chibios.org/dokuwiki/doku.php?id=chibios:kb:timingI think it is much simpler
Theo
Posted: Tue Feb 09, 2016 10:33 am
by RTOSman
Hello
it's veery complicated to explain you my project, if you want i hava e function that i took every sample in 10 MS this is in matlab simulink. after code generation.
and i did 9 because the time between the wakup of thread and my function is 1
so to do the 10 ms calculation, i did 9 so 9+1=10 and here a did my simulink modele. and mt led blink exactely everry 1 ms just over time ihave errors. after 3 minute i have errors of 40 MS.
Du coup tu parles français ?
Posted: Tue Feb 09, 2016 1:19 pm
by tfAteba
Yes has my location suggest I speack french
why? you want to discust in french?
Ok, i'm understand, wich chibios and board do you use for your project?
Posted: Tue Feb 09, 2016 2:10 pm
by RTOSman
Bonjour, enfaîte j'au une arduino uno. j'ai la bibliothèque chibio 3.0.3.
je voudrais faire des test pour maîtriser le temps. donc j'ai intégré une fonction qui génère un signale carré de fréquence de 1. le problème c'est que au fil du temps la fréquence augmente un peux, quand je dépasse 3 minutes par exemple la j'ai un retarde de 40 MS. je sais pas comment faire pour éliminer ce retard ?
Vous avez des solutions a me proposer ?
vous pouvez me donnez un algo pour bien exécuter une tache chaque 10 MS !!
Merci d'avance
Posted: Tue Feb 09, 2016 2:32 pm
by tfAteba
How do you mesure the time?
My solution would be to fucus together on the code you did to resolve the problem.
cheers, Theo
