AVR os-less OSAL Topic is solved
Moderators: utzig, tfAteba
Marco
Has thanked: 4 times
Been thanked: 11 times
Re: AVR os-less OSAL
Postby Marco » Fri Oct 21, 2016 8:34 am
Ok, attached are two patches. One for the nop insructions in osal.h and the other one for hal_serial_lld.c.
Marco
osal.h.patch.zip
Add nop after sei
(362 Bytes) Downloaded 96 times
hal_serial_lld.c.patch.zip
Improvements in hal_serial_lld.c
(588 Bytes) Downloaded 98 times
utzig
Been thanked: 19 times
Re: AVR os-less OSAL  Topic is solved
Postby utzig » Fri Oct 21, 2016 12:57 pm
Applied, thanks!
Marco
Postby Marco » Mon Nov 28, 2016 5:18 pm
I'd like to use a virtual timer in the AVR os-less OSAL. Is it possible to make the vtSetI and vtResetI functions public?
Marco
utzig
Postby utzig » Tue Nov 29, 2016 12:12 pm
The rationale for it being the way it is, is something that only Giovanni will know. But IMO we could make vtIsArmedI, vtSetI and vtResetI public. I would suggest changing the names to something like osalVtIsArmedI, osalVtSetI, osalVtResetI.
Also it bothers me a lot that os-less/ARMCMx/osal.c and os-less/AVR/osal.c have the same contents. Maybe moving one of them to "common" and updating the makefiles?
Giovanni, what do you think?
Has thanked: 876 times
Been thanked: 750 times
Postby Giovanni » Tue Nov 29, 2016 7:33 pm
Those function do not belong to the "osal" namespace because the underlying OS could (and usually does) have its own timeout mechanism, see RT and NIL for example. RT has virtual timers, NIL does it differently.
Marco
Postby Marco » Wed Nov 30, 2016 3:14 pm
I understand, but since there is no underlying OS there is no timeout mechanism available. Since the os-less OSAL already has a timers implementation i thought it can be made public so the application can use it as well.
Marco
Postby Giovanni » Wed Nov 30, 2016 4:43 pm
You can make it public, I didn't want to establish it as a standard OSAL API.
Perhaps I should make those VTs a GPL library and make those available even without the OS, it is an useful and well tested mechanism.
Marco
Postby Marco » Wed Nov 30, 2016 5:20 pm
Yes that would be a good solution i think. On the other hand, i guess that means the user needs it's own timer implementation if he doesn't want GPL?
Marco
Postby Giovanni » Wed Nov 30, 2016 5:29 pm
It could be Apache 2.0, no problems, but in that case I couldn't add a "tickless" mode like in RT. Note that the timers in OSAL are a stripped down version of those in RT.
Marco
Postby Marco » Thu Dec 01, 2016 12:24 pm
I'm not sure if the following makes sense, but how about having two different implementations? A ticked version as Apache 2.0 and a tickless version as GPL? You can always use the ticked version but if you need a better (lower power) version then you need the tickless one.
Marco
Return to “AVR Support”
Users browsing this forum: tfAteba and 2 guests
