compile error: CH_DBG_TRACE_MASK not defined Topic is solved
Moderators: utzig, tfAteba
orion
Has thanked: 4 times
Postby orion » Tue Nov 28, 2017 7:03 pm
Hi there,
Since last weekend, when trying to compile one of the AVR test or demo applications in the trunk branch, I get an error similar to the one below;
Compiling chsys.c
In file included from ../../../../os/rt/include/ch.h:91:0,
                 from ../../../../os/rt/src/chsys.c:36:
../../../../os/rt/include/chchecks.h:212:2: error: #error "CH_DBG_TRACE_MASK not defined in chconf.h"
Aṕparently, this is caused by a change in os/rt/include/chchecks.h, which no longer defines CH_DBG_TRACE_MASK, but throws an error instead if CH_DBG_TRACE_MASK isn't defined.
Checking the chconf.h file in the AVR apps' chconf.h file I see the line
#define CH_DBG_ENABLE_TRACE                 CH_DBG_TRACE_MASK_DISABLED
but no line defining CH_DBG_TRACE_MASK, whereas in some STM32 chconf.h file I see
#define CH_DBG_TRACE_MASK                   CH_DBG_TRACE_MASK_DISABLE
Does this means the AVR files need to be updated? Is the update just the insertion of the line above?
tfAteba
Has thanked: 91 times
Been thanked: 48 times
Re: compile error: CH_DBG_TRACE_MASK not defined
Postby tfAteba » Sun Dec 03, 2017 2:34 pm
Hi there, first of all I want to apologize for my long silence,
Last week was so sad for me, I lost my father, so I was to the funeral.
But now I'm back, and I will look at you problem the week as soon as possible and give you a feed back.
Thank you for your Patience.
regards,
Theo.
orion
Postby orion » Sun Dec 03, 2017 4:28 pm
Theo,
Sorry to hear about your father. Take your time. This problem is not a pressing one. Cheers,
Hermano
Has thanked: 1074 times
Been thanked: 921 times
Postby Giovanni » Sun Dec 03, 2017 4:33 pm
I recently introduced stronger checks in RT, that message is the result of that change, just take a chconf.h from a working demo, make sure to set the proper values in it by taking them from the old one.
Better an error message than unaligned files in demos.
tfAteba
Re: compile error: CH_DBG_TRACE_MASK not defined  Topic is solved
Postby tfAteba » Wed Dec 20, 2017 9:34 pm
Hi all,
I have just update all configuration files to remove this compilation error.
regards,
Theo.
Return to “AVR Support”
