Manual chSchRescheduleS() neccessary?
ulikoehler
Postby ulikoehler » Thu Apr 02, 2015 5:15 am
I've written a SC16IS752IPW driver (2ch UART expander) for ChibiOS 2.x some time ago.
Todo I've tried it out with ChibiOS 3.x trunk.
It uses a custom SerialDriver object. New incoming bytes cause an event flag notification in the RX/TX thread.
When I use the 2.x code, I trigger this assertion:
  /* The following condition can be triggered by the use of i-class functions
     in a critical section not followed by a chSchResceduleS(), this means
     that the current thread has a lower priority than the next thread in
     the ready list.*/
  chDbgAssert((ch.rlist.r_queue.p_next == (thread_t *)&ch.rlist.r_queue) ||
              (ch.rlist.r_current->p_prio >= ch.rlist.r_queue.p_next->p_prio),
              "priority violation, missing reschedule");
I had to modify my code like this:
static void txQueueNotifyA(io_queue_t* q) {
    (void)q;
    chEvtSignalI(sc16Thread, EVENT_TXA);
    //Since ChibiOS 3
    chSchRescheduleS();
I believe the manual reschedule call should not really be neccessary. Just like with chEvtSignal(), chEvtSignalI() should automatically reschedule. Maybe this is a corner case that has not been considered yet. As far as I know there are no tests (I searched the testhal and test folder) involving sdObjectInit().
Is there a better way to solve this?
Best regards, Uli
Has thanked: 1111 times
Been thanked: 937 times
Re: Manual chSchRescheduleS() neccessary?
Postby Giovanni » Thu Apr 02, 2015 8:03 am
It is correct, those notification functions are called from thread context so rescheduling does not happen automatically for I-Class functions, manual rescheduling is required.
The difference between 2.6 and 3.0 is that 3.0 complains about it with an assertion, it is much more stringent on this kind of subtle issues.
Note that I-class functions never reschedule, ISRs are rescheduled at their end if necessary.
pascalhuerst
Postby pascalhuerst » Tue Feb 06, 2018 3:48 pm
Hey everyone,
probably I missed something, but how am I supposed to reschedule if there is no I-class variant of chSchReschedule_() ?
Or put differently, if I use I-class variant of chEvtSignalI() / chThdResumeI() I seem to be in ISR-Context, but there is no I-class variant to reschedule, how do I do that?
Kind regards
Pascal
Postby Giovanni » Tue Feb 06, 2018 3:59 pm
Rescheduling is done automatically on ISR exit, if required, in the epilogue code.
rew
Been thanked: 13 times
Postby rew » Wed Jul 17, 2024 7:27 pm
Just FYI:
I wanted to know what was explained in this thread. I checked the docs for chSchRescheduleS and it didn't explain it one bit.
Something like:
This call is necessary if you call XXX or YYY from thread context, if a reschedule becomes necessary in ISR context, the reschedule is done automatically on ISR exit.
in the doc for chSchRescheduleS would have been a lot clearer.
(now the process is: "copy some code", compile, find out you can't call chSchRescheduleS from interrupt, look for I class version. Not found. Check docs. Nothing. eventually find this.
Return to “ChibiOS/RT”
