I ported the ST API to Chibios, in order to support the STUSB4500 USB PD IC. I will clean it up a bit more and make it resemble the usual chibios driver API.
Where would be the best place to put it, so that it can be used by others as well? It does not really fit into the HAL/Contrib drivers, it is not low-level enough.
Best regards
STUSB4500 USB power delivery driver
Re: STUSB4500 USB power delivery driver
It depends, if it is an application then it could go into the "user projects" forum (with a link to the project), if it is more like a driver then it could go into the community repository initially.
Users browsing this forum: No registered users and 32 guests
