Working and simple example of Events, Listeners and Flags
KalRal
Postby KalRal » Thu Apr 16, 2020 7:33 pm
I have seen several forum topics that starts with having doubts about Events, Listeners and Event Flags. I also had some doubts and researched a bit about how they work and the forum topics were also really helpful. So to give something back to community, I have a simple working example that uses
event_source_t, event_listener_t and eventflags_t
in the same example.
    ChibiOS - Copyright (C) 2006..2016 Nicolas Reinecke
// clang-format off
#include "ch.hpp"
#include "string.h"
#include "usbcfg.h"
#include "chprintf.h"
// clang-format on
/// Define an EventSource
event_source_t ledEventSource;
/// Define event flags
#define LED3 (eventflags_t)0
#define LED4 (eventflags_t)1
#define LED5 (eventflags_t)2
#define LED6 (eventflags_t)6
 * @brief chp Stream for printing variables on USB
BaseSequentialStream* chp = (BaseSequentialStream*)(&SDU1);
class BlinkerThread : public chibios_rt::BaseStaticThread<512>
  protected:
    void main(void) override
        setName("BlinkerThread");
        // Define an event listener
        event_listener_t ledEventListener;
        // Register for the event
        chEvtRegisterMask(&ledEventSource, &ledEventListener, EVENT_MASK(0));
        eventflags_t flags;
        while(true)
            chEvtWaitAny(EVENT_MASK(0));
            flags = chEvtGetAndClearFlags(&ledEventListener);
            if(flags == LED3)
                palToggleLine(LINE_LED3);
            else if(flags == LED4)
                palToggleLine(LINE_LED4);
            else if(flags == LED5)
                palToggleLine(LINE_LED5);
            else if(flags == LED6)
                palToggleLine(LINE_LED6);
  public:
    BlinkerThread(void)
        : BaseStaticThread<512>()
 * Application entry point.
int main(void)
     * System initializations.
     *   RTOS is active.
    chEvtObjectInit(&ledEventSource);
    chibios_rt::System::init();
    // Initialize Serial-USB driver
    sduObjectInit(&SDU1);
    sduStart(&SDU1, &serusbcfg);
     * Activates the USB driver and then the USB bus pull-up on D+.
     * Note, a delay is inserted in order to not have to disconnect the cable
     * after a reset.
    chThdSleepMilliseconds(1500);
    /// Start thread
    BlinkerThread blinkerThread;
    blinkerThread.start(NORMALPRIO + 1);
    while(1)
        chEvtBroadcastFlags(&ledEventSource, LED3);
        chThdSleepMilliseconds(50);
        chEvtBroadcastFlags(&ledEventSource, LED4);
        chEvtBroadcastFlags(&ledEventSource, LED5);
        chEvtBroadcastFlags(&ledEventSource, LED6);
I hope, i haven't made any mistakes. Please let me know if I have.
Thanks
Re: Working and simple example of Events, Listeners and Flags
Postby Giovanni » Thu Apr 16, 2020 8:22 pm
Just a note, flags are bit masks, you should handle those as such, new flags are ORed to existing ones. your code seems to assume that flags are just like messages:
LED6 is 6 so it includes flags 4 and 2, 2 is your LED5. Assuming you get events for LED4, LED5 and LED6, you would get 7 (6!2!1). This does not happen in your code because you send events with intervals so those are never ORed together.
In that example you could also have used messages or mailboxes.
KalRal
Postby KalRal » Fri Apr 17, 2020 8:21 am
Cool. Thanks Giovanni. Will keep that in mind. Yeah you are right, I could have gone with the Mailboxes, but just wanted to learn about using events. I also have an example projects repository that contains all the features that I have tried out in Chibios.
Chibios Projects
Return to “ChibiOS/RT”
Users browsing this forum: No registered users and 38 guests
