hi ,
I am trying to use statistical module for deriving the CPU load, but i have some question that I would ask the expert here.
Currently , my system(tickless) is running quite a number of thread, I understand that the statistical module could be able to calculate the time for each thread and hence derived the CPU Load time.
My question is if it also work with Interrupt design . An example is using an interrupt to spin of couple of thread …, does the statistical module work? under what kind of situation that this statistical module cannot be use.
i am a newbie , and i hope that expert here could guide me along.
Thank you and Best Regards
albert
Questions on CPU load using statistic module.
Re: Questions on CPU load using statistic module.
The stats module does not take into account the time spent in ISRs but that should be small compared to time spent into threads. ISR time is added to the threads preempted by the IRQ. Over time ISR time is statistically spread on all threads proportionally to their CPU usage.
- Been thanked: 17 times
I mostly use Cortex-M0 based MCUs. They are missing some debugging hardware element that is required for the ChibiOS statistics module to work. So this is how I get load statistics instead:
I modify the idle thread enter and exit hooks, disable a GPIO on idle enter, enable the GPIO on idle leave. Then I can view the GPIO on the oscilloscope, every time the GPIO is high, ChibiOS is under load and not idle. I can then let the scope calculate the load percentage.
Also I can use the scope trigger system to find the longest consecutive load sequence in some test scenario. I can also use the other channels of the scope to compare external signals that influence my system to the load at that moment. Or compare the reaction latency of the system to an external event (as observed on the other scope channels) to the load situation at that moment.
This works quite well for my needs. If needed it could even be extended to show different threads on different GPIOs or similar.
Giovanni wrote:Hi,
Thank for the clarification. I will try out the stat module. In case , i face any more problem that I could not solve.... Pardon me for pestering you again.
electronic_eel wrote:I mostly use Cortex-M0 based MCUs. They are missing some debugging hardware element that is required for the ChibiOS statistics module to work. So this is how I get load statistics instead:
This look like a hardware solution , I am using M4 based MCUs , so far the compiler/linker never complain when i use the Statistic module, it throwing some number and I think i could use your method to verify if they are indeed correct. Thank you !!!
The cortex-m port uses the internal SWT cycles couter for time measurement, this is missing on the cortex-m0, this is why that service is not available on M0s.
With some work it could be made to work with some other STM32 counter, also the TIMx used for systick.
Users browsing this forum: No registered users and 47 guests
