Hello
I was asked to quantify how many CPU cycles are required for scheduling. I'm going to do an initial development for a series of devices. Could someone guide me to a place where I can find the number of CPU cycles to do the following:
* Preempt low priority thread and schedule high priority thread.
* Schedule from thread to thread on same priority. E.g. first thread blocked on a semaphore.
* Schedule from inactivated (e.g. blocking on a semaphore) high priority thread to low priority pending thread.
* Number of cycles from interrupt becoming active until first instruction of the user interrupt handler.
* Schedule from end of interrupt back to the thread preempted by this interrupt.
* Schedule from end of interrupt to a task higher than the thread that the interrupt has preempted.
* For how many CPU cycles get interrupts disabled while scheduling?
I expect the applications will run under the following:
* Cortex-M0+/M4/M7 depending on the enabled features.
* A typical configuration for an application with 16-64 tasks and 8 priority levels
* How much adds an FPU?
* How much adds an MMU/MPU?
Thanks very much
Scheduling overhead
- Has thanked: 1074 times
- Been thanked: 921 times
Re: Scheduling overhead
Try looking under /doc/quality/rt/unittest. there are benchmarks run on various architectures, compilers and settings (with and without FPU). The benchmarks code is under /test/rt/source/test/rt_test_sequence_012.c, it covers some of your cases.
Answering in a detailed manner to all your questions would require a specific test setup.
