GPT callback not called if there is no sleep in the main thread
enrico.dallavia
Has thanked: 2 times
Postby enrico.dallavia » Mon Dec 07, 2020 2:02 pm
Good morning,
I have a problem understanding GPT. I belived that it will use a hardware timer to trigger a function periodically, but it seems to me that, if I don't put a minimum sleep in the code, the callback is never called. I would use the callback to update a timestamp variable. Any clue about what I'm doing wrong? If I use the CubeMx project with interrupt handler, it works fine as I am expected.
Many thanks
#include "ch.h"
#include "hal.h"
#include "chprintf.h"
#include "shell.h"
#include "usbcfg.h"
static uint32_t timestamp = 0;
static void TimeStampCallback()
  timestamp += 1;
static GPTConfig gptCfg = {
  1000000,              /* timer clock.*/
  TimeStampCallback,     /* Timer callback.*/
  0,
  0
#define GPT_RESOLUTION (5) // 5us each tick
 * Green LED blinker thread, times are in milliseconds.
static THD_WORKING_AREA(waThread2, 128);
static THD_FUNCTION(Thread2, arg) {
  (void)arg;
  chRegSetThreadName("blinker2");
  while (true) {
    if(timestamp > 50000)
      palClearPad(GPIOG, GPIOG_LED3_GREEN);
      timestamp = 0;
    // chThdSleepMicroseconds(1); // with the sleep it works, without the timestamp variable seems to be never updated
/* Command line related.                                                     */
#define SHELL_WA_SIZE   THD_WORKING_AREA_SIZE(2048)
static const ShellCommand commands[] = {
  {NULL, NULL}
static const ShellConfig shell_cfg1 = {
  (BaseSequentialStream *)&SDU1,
  commands
/* Initialization and main thread.                                           */
 * Application entry point.
int main(void) {
   * System initializations.
   *   RTOS is active.
   * Shell manager initialization.
  shellInit();
   * Initializes a serial-over-USB CDC driver.
  sduObjectInit(&SDU1);
  sduStart(&SDU1, &serusbcfg);
  // configure the GPT timer
  gptStart(&GPTD1, &gptCfg);
  gptStartContinuous(&GPTD1, GPT_RESOLUTION); // dT = 1,000,000 / GPT_RESOLUTION =  x us
   * Activates the USB driver and then the USB bus pull-up on D+.
   * Note, a delay is inserted in order to not have to disconnect the cable
   * after a reset.
  chThdSleepMilliseconds(1000);
   * Creating the blinker threads.
  chThdCreateStatic(waThread2, sizeof(waThread2),
                    NORMALPRIO, Thread2, NULL);
   * Normal main() thread activity, spawning shells.
  while (true) {
    if (SDU1.config->usbp->state == USB_ACTIVE) {
      thread_t *shelltp = chThdCreateFromHeap(NULL, SHELL_WA_SIZE,
                                              "shell", NORMALPRIO + 1,
                                              shellThread, (void *)&shell_cfg1);
      chThdWait(shelltp);               /* Waiting termination.             */
Has thanked: 1074 times
Been thanked: 921 times
Re: GPT callback not called if there is no sleep in the main thread
Postby Giovanni » Mon Dec 07, 2020 8:26 pm
Make timestamp volatile.
enrico.dallavia
Postby enrico.dallavia » Wed Dec 09, 2020 11:15 am
YES! it works.
I wonder why with the sleep it worked (even if not so accurate)
Thank yoiu very much!!
Return to “ChibiOS/HAL”
