*** ChibiOS/HAL MFS Test Suite
*** Compiled: Dec 17 2021 - 19:56:25
*** Platform: STM32F722 Very High Performance with DSP and FPU
*** Test Board: STMicroelectronics STM32 Nucleo144-F722ZE
*** Text size: 24468 bytes
*** RO data size: 4828 bytes
*** Data size: 0 bytes
*** BSS size: 9928 bytes
=== Test Sequence 1 (Functional tests)
--- Test Case 1.1 (Testing mfsStart() behavior)
--- Result: SUCCESS
--- Test Case 1.2 (Checking for non existing record)
--- Result: SUCCESS
--- Test Case 1.3 (Creating, updating and erasing a record)
--- Result: SUCCESS
--- Test Case 1.4 (Erasing the whole storage and re-initialization)
--- Result: SUCCESS
--- Test Case 1.5 (Testing storage size limit)
--- Result: SUCCESS
--- Test Case 1.6 (Testing garbage collection by writing)
--- Result: SUCCESS
--- Test Case 1.7 (Testing garbage collection by erasing)
--- Result: SUCCESS
=== Test Sequence 2 (Transaction Mode tests)
--- Test Case 2.1 (Committing a transaction)
--- Result: SUCCESS
--- Test Case 2.2 (Rolling back a transaction)
--- Result: SUCCESS
--- Test Case 2.3 (Transaction triggering an early garbage collect)
--- Result: SUCCESS
=== Test Sequence 3 (API Invalid Cases tests)
--- Test Case 3.1 (Initialization error from APIs)
--- Result: SUCCESS
--- Test Case 3.2 (Erasing non existing record)
--- Result: SUCCESS
Final result: SUCCESS
STM32F722/23/32/33/30 HAL EFL driver
I tested it with the MFS test suite. See the attached patch. Based off of latest from stable_20.3.x
Updated with F730x support.
- f7_efl.patch.tar.gz
- (16.48 KiB) Downloaded 186 times
STM32F7xx (all known versions) HAL EFL driver
Updated to support all known version of STM32F7xx . There, I guess that's done now
https://github.com/faisal-shah/ChibiOS. ... efl_20.3.x
- (18.22 KiB) Downloaded 180 times
Re: STM32F722/23/32/33/30 HAL EFL driver
Patch to be applied on stable_20.3.x r15216
$ patch -p1 -i f7_efl-5deb082.patch
You can see commit history here: https://github.com/faisal-shah/ChibiOS. ... efl_20.3.x
- f7_efl-5deb082.patch.tar.gz
- (27.36 KiB) Downloaded 183 times
$ patch -p1 -i f7_efl-c55268ce2.patch
I've also created a patch which shows the incremental diff between this latest commit, and the previous patch I posted above (in case you've already reviewed the previous one).
f7_efl-c55268ce2-5deb08218.patch
I successfully tested this with F722 nucleo, F746 disco, and F769 disco (in single and dual bank modes) - and they all pass the EFL-MFS testhal test suite.
- f7_efl-c55268ce2-5deb08218.patch.tar.gz
- (13.68 KiB) Downloaded 191 times
- f7_efl-c55268ce2.patch.tar.gz
- (37.44 KiB) Downloaded 182 times
Patches don't apply, lots of details changed, the driver itself probably is fine.
