USB stall error
Viljami
Has thanked: 13 times
Re: USB stall error
Postby Viljami » Fri Aug 26, 2022 12:49 pm
Hello again Giovanni!
Giovanni wrote:Hi,
Is it possible your descriptor is wrong somehow? it happens after the host retrieves it.
Do you mean especially (USB) device descriptor or configuration one or what?
BR
Viljami
Re: USB stall error
Postby Giovanni » Fri Aug 26, 2022 12:59 pm
The one sent by USB_REQ_GET_DESCRIPTOR but you should check anything is exchanged before the stall.
Viljami
Re: USB stall error
Postby Viljami » Fri Aug 26, 2022 3:23 pm
I checked, debugged etc. my code.
USB_REQ_GET_DESCRIPTOR requests USB_DESCRIPTOR_DEVICE_QUALIFIER; I added handling for that.
The following is from default_handler (hal_usb.c):
  case (uint32_t)USB_RTYPE_RECIPIENT_DEVICE | ((uint32_t)USB_REQ_GET_DESCRIPTOR << 8):
  case (uint32_t)USB_RTYPE_RECIPIENT_INTERFACE | ((uint32_t)USB_REQ_GET_DESCRIPTOR << 8):
    /* Handling descriptor requests from the host.*/
    dp = usbp->config->get_descriptor_cb(usbp, usbp->setup[3],
                                         usbp->setup[2],
                                         get_hword(&usbp->setup[4]));
    if (dp == NULL) {
      return false;
    /*lint -save -e9005 [11.8] Removing const is fine.*/
    usbSetupTransfer(usbp, (uint8_t *)dp->ud_string, dp->ud_size, NULL);
    /*lint -restore*/
    return true;
After adding of USB_DESCRIPTOR_DEVICE_QUALIFIER the program running here returns true but still USB stalls.
There is no any handling for USB_DESCRIPTOR_DEVICE_QUALIFIER in my earlier ChibiOS code. It's possible that I have to go through my USB descriptors.
BR
Viljami
Return to “ChibiOS/HAL”
