Hello!
If a USB stall error occurs is there any common procedure to clear/solve it?
USB stall error
Re: USB stall error
It depends on the cause of the stall, if it is an unimplemented command then you need to implement the command handler (not all CDC commands are implemented by default).
Re: USB stall error
Giovanni wrote:Hi,
Hello Giovanni and thanks for your quick response!
Could you describe causes which generate USB stalls?
BR
Viljami
Re: USB stall error
Find all instances of "usb_lld_stall" in hal_usb.c, those are all the possible causes, mainly are unimplemented EP0 commands.
Re: USB stall error
Giovanni wrote:Find all instances of "usb_lld_stall" in hal_usb.c, those are all the possible causes, mainly are unimplemented EP0 commands.
Hello again!
Could you mention USB limitations? I am working with ChibiOS RT version 21.11.1.
BR
Viljami
Re: USB stall error
Simply you have to implement the EP0 commands you need, there are no intrinsic limitations.
See the "requests_hook_cb" callback in the USBConfig structure. An example of commands implementation is in sduRequestsHook() into hal_serial_usb.c.
It is complex matter, knowledge of USB spec is required. Non answering to a command causes those stalls.
Re: USB stall error
Hello again!
I want tell more about this stall error.
I have a ChibiOS based system which applies my own defined messages. I apply bulk transfer in my system. My system is capable to handle (receive and transmit) the first my own defined USB message but second one fails because of the stall error. A function bool requestsHook(USBDriver *usbp) was an empty implementation which just returned FALSE.
The next step was to debug and implement code for ep0 into bool requestsHook(USBDriver *usbp). I noticed that bool requestsHook(USBDriver *usbp) receives
The implemented code did not solve my problem; the earlier stall problem still occurs (the first my own defined USB message is received and transmitted successfully but the second one fails because of the stall error).
Here is the code:
BR
Viljami
- * USB_REQ_SET_ADDRESS
* USB_REQ_SET_CONFIGURATION
* USB_REQ_GET_DESCRIPTOR
Here is the code:
bool requestsHook(USBDriver *usbp) {
// (void) usbp;
if ((usbp->setup[0] & USB_RTYPE_DIR_MASK) == USB_RTYPE_DIR_HOST2DEV)
if (usbp->setup[1] == USB_REQ_SET_ADDRESS)
set_address(usbp);
usbSetupTransfer(usbp, NULL, 0, NULL);
return true;
else if (usbp->setup[1] == USB_REQ_SET_CONFIGURATION)
if (usbp->configuration != usbp->setup[2])
/* If the USB device is already active then we have to perform the clear
procedure on the current configuration.*/
if (usbp->state == USB_ACTIVE)
/* Current configuration cleared.*/
osalSysLockFromISR ();
usbDisableEndpointsI(usbp);
osalSysUnlockFromISR ();
usbp->configuration = 0U;
usbp->state = USB_SELECTED;
_usb_isr_invoke_event_cb(usbp, USB_EVENT_UNCONFIGURED);
if (usbp->setup[2] != 0U)
/* New configuration.*/
usbp->configuration = usbp->setup[2];
usbp->state = USB_ACTIVE;
_usb_isr_invoke_event_cb(usbp, USB_EVENT_CONFIGURED);
return true;
else if ((usbp->setup[0] & USB_RTYPE_DIR_MASK) == USB_RTYPE_DIR_DEV2HOST)
if (usbp->setup[1] == USB_REQ_GET_DESCRIPTOR)
const USBDescriptor *dp = usbp->config->get_descriptor_cb(usbp, usbp->setup[3],
usbp->setup[2],
get_hword(&usbp->setup[4]));
if (dp == NULL)
return false;
usbSetupTransfer(usbp, (uint8_t *)dp->ud_string, dp->ud_size, NULL);
return true;
return FALSE;
BR
Viljami
Re: USB stall error
You are not supposed to process default messages in that handler (USB_REQ_SET_CONFIGURATION, USB_REQ_SET_ADDRESS etc), those are processed in the driver if your installed handler returns false.
Just handle your messages and return true, else return false and the driver will handle default ones, the stall only occurs if both your handle AND the default handler do not recognize some message.
Re: USB stall error
Hello again Giovanni!
As I mentioned in the previous mail
were the only messages what I catched by debugging; I did not see any my own USB messages in bool requestsHook(USBDriver *usbp).
BR
Viljami
BR
Viljami
Re: USB stall error
Is it possible your descriptor is wrong somehow? it happens after the host retrieves it.
Users browsing this forum: No registered users and 22 guests
