undefined reference to `palEnableLineEvent'
AnSc
Been thanked: 2 times
Postby AnSc » Wed May 11, 2022 3:53 pm
I wanted to implement this method for event based reading buttons from this article: https://www.playembedded.org/blog/buttons-stm32/
However, I get the error
I did set #define HAL_USE_PAL TRUE in halconf.h
I can see the definition of it in C:\ChibiStudio\chibios2111\os\hal\include\hal_pal.h
and I did #include "hal.h" in my source file.
What am I missing? I'm using a STM32F103 if that makes any difference.
/** this file contains buttons related code */
#include "ch.h"
#include "hal.h"
#include "board.h"
void button_cb(void *arg){
  (void)arg;
  if(palReadLine(LINE_BUTTON_A) == PAL_HIGH){ // rising edge starts timer
    startTimeA = chVTGetSystemTimeX();
  else { // falling edge reads timer and desides if clicked or long press
    if(chVTIsSystemTimeWithinX(startTimeA, startTimeA + TIME_MS2I(LONGPRESSEDMS))){
      // short pressed
      active.A = CLICKED;
    else { // long press
      active.A = LONGPRESSED;
  if(palReadLine(LINE_BUTTON_B) == PAL_HIGH){ // rising edge starts timer
    startTimeB = chVTGetSystemTimeX();
    if(chVTIsSystemTimeWithinX(startTimeB, startTimeB + TIME_MS2I(LONGPRESSEDMS))){
      // short pressed
      active.B = CLICKED;
      active.B = LONGPRESSED;
  if(palReadLine(LINE_BUTTON_L) == PAL_HIGH){ // rising edge starts timer
    startTimeL = chVTGetSystemTimeX();
    if(chVTIsSystemTimeWithinX(startTimeL, startTimeL + TIME_MS2I(LONGPRESSEDMS))){
      // short pressed
      active.L = CLICKED;
      active.L = LONGPRESSED;
  if(palReadLine(LINE_BUTTON_R) == PAL_HIGH){ // rising edge starts timer
    startTimeR = chVTGetSystemTimeX();
    if(chVTIsSystemTimeWithinX(startTimeR, startTimeR + TIME_MS2I(LONGPRESSEDMS))){
      // short pressed
      active.R = CLICKED;
      active.R = LONGPRESSED;
  if(palReadLine(LINE_BUTTON_ROT) == PAL_HIGH){ // rising edge starts timer
    startTimeRot = chVTGetSystemTimeX();
    if(chVTIsSystemTimeWithinX(startTimeRot, startTimeRot + TIME_MS2I(LONGPRESSEDMS))){
      // short pressed
      active.ROT = CLICKED;
      active.ROT = LONGPRESSED;
/** set up the buttons */
void buttonInit(void){
  palEnableLineEvent(LINE_BUTTON_A,   PAL_EVENT_MODE_BOTH_EDGES);
  palEnableLineEvent(LINE_BUTTON_B,   PAL_EVENT_MODE_BOTH_EDGES);
  palEnableLineEvent(LINE_BUTTON_L,   PAL_EVENT_MODE_BOTH_EDGES);
  palEnableLineEvent(LINE_BUTTON_R,   PAL_EVENT_MODE_BOTH_EDGES);
  palEnableLineEvent(LINE_BUTTON_ROT, PAL_EVENT_MODE_BOTH_EDGES);
  palSetLineCallback(LINE_BUTTON_A,   button_cb, NULL);
  palSetLineCallback(LINE_BUTTON_B,   button_cb, NULL);
  palSetLineCallback(LINE_BUTTON_L,   button_cb, NULL);
  palSetLineCallback(LINE_BUTTON_R,   button_cb, NULL);
  palSetLineCallback(LINE_BUTTON_ROT, button_cb, NULL);
Has thanked: 990 times
Been thanked: 839 times
Re: undefined reference to `palEnableLineEvent'
Postby Giovanni » Wed May 11, 2022 4:25 pm
In halconf.h you also need to set:
#define PAL_USE_CALLBACKS TRUE
#define PAL_USE_WAIT FALSE
AnSc
Postby AnSc » Wed May 11, 2022 4:51 pm
Thanks a lot. :D
Somehow I missed this information in the article.
It's right there… :roll:
Return to “ChibiOS/HAL”
