Hi Team,
I am trying to implement a driver using SPI for the ADBMS1818 chip which is used to measure the Cell voltages of battery cells. To start measuring the voltage using the ADC . I have to do a start poll operation (PLADC). After which I shall use another command to read the ADC values (say for eg : RDCVA).
When I ask the chip to start measuring ( PLADC) I have to wait for a specific amount of time depending on the number of cells being measured. The operation is shown in the image attached.
My doubt is with PLADC command. Is there a way to know when the request for conversion has been done based on the SDO line activity? I currently use spiStartExchange. Can `end_cb` in the SPI device descriptor be used for this purpose ?
Regards,
Akshai
SPI Hal - Waiting to MISO line to be released
Re: SPI Hal - Waiting to MISO line to be released
I think you could use GPIO (PAL driver) and poll for completion or to wait for a rising edge.
You could also keep doing spiReceive() until you get an 0xFF if the extra clocks are tolerated by the ADC.
Thank you for the reply. Unfortunately, I cannot wait as it will kill the timings. Is there a possibility for an asynchronous way to do it?
Regards,
Akshai
Regards,
Akshai
Waiting for a rising edge is asynchronous, it triggers a callback. See PAL callbacks.
Thanks Giovanni. I shall explore that
Regards,
Akshai
Regards,
Akshai
Instead of polling via GPIO I ended up sending an empty requests using DMA and have callback check for `0xFF` in Rx buffer which shows the device is free . This ended up being the easiest option
Users browsing this forum: No registered users and 29 guests
