using 21.11.3, I am surprised by the cpu load of using sdGet function :
° stm32F4 @ 168Mhz
° uart : 115200 bauds, 2400 bytes/ second on the line
° all _DBG_ stuff set to FALSE to minimise cpu load overhead
° STATISTIC enabled to measure cpu load
I have a thread which only call sdGet(TIME_INFINITE) in an infinite loop and that eat 2.5% of cpu, is it surprising or is it normal ?
It means more than 1500 cpu cycles/bytes, only for the thread, not counting the cpu cycles in the ISR.
trying to step in the function, I don't see anything obvious.
any idea ?
Alexandre
serial driver cpu load
- Has thanked: 1076 times
- Been thanked: 922 times
- Contact:
Re: serial driver cpu load
It is a buffered driver and you should consider time the spent for IRQ servicing, circular buffer management, context switch to the waiting thread and the non-negligible weight of statistics themselves (those inject code in an lot of critical places).
That number looks way too high anyway, are you confident it is an accurate measurement?
Note that on repository some bugs related to statistics have been fixed, there is a chance you are affected by that.
viewtopic.php?f=24&t=6208
- alex31
- Has thanked: 38 times
- Been thanked: 62 times
- Contact:
I use the same shell thread command since a long time, and the numbers looks realistic, thread that does nearly nothing are close to 0%, only readBytes thread, which for the test does only a sdGet without using the value, rise at more that 2%
addr stack frestk prio refs state time percent name
20001760 20000784 856 128 1 SLEEPING 1 0.00% main
200016C0 2000166C 144 1 1 READY 25887 95.70% idle
200022E8 200021D4 168 128 1 SLEEPING 1 0.00% blinker
200020B0 20002034 344 128 1 READY 642 2.36% readBytes
2001FFA0 2001FE84 3976 128 1 CURRENT 3 0.00% Enhanced_shell
20001B48 20001AEC 400 129 1 WTMSG 15 0.04% serialPrint
Interrupt Service Routine 505 1.86% ISR
cpu load = 4.29%
thanks for the link, the behavior is better, does not change the figures, but before the fix, the cpu load of thread start at zero and take time to reach an asymptote, with the fix, it's immediately good at startup, but nevertheless, still high.
Is there is a way to find if it's a side effect of statistics module usage, or if it is in the serial driver impl that CPU is spent ?
by the way, if I use an UARTDriver, reading one byte at a time with uartReceiveTimeout, the cpu load is roughly the same, just a little bit higher, which is odd since it has to manage DMA.
Alexandre
- Contact:
One byte at time means one interrupt for each byte anyway.
You could give a try to the SIO driver which is unbuffered, it relies on the internal HW FIFO. It is not yet available for the F4 sadly.
The statistics module injects code in chSysLock()/Unlock() and context switch which are very critical, this is why it can have a significant impact.
I've done a similar thing on an F7 at 168MHz, and think I was getting similar figures, albeit running the serial port at only 9600 baud. Unfortunately I don't seem to have noted any figures, and have put that project to one side for now. Somewhat different approach and environment, though:
All debug stuff enabled
Using modified serial driver which does a callback on received character, rather than buffering it
The receiver callback passes the character to a state machine (still within the ISR) which decodes the protocol and updates a buffer.
A thread is only activated when a valid packet is received.
So I still have the interrupt per character, but one thread switch per packet (8-20 characters), and doing a bit more processing in ISR than you.
Using 21.11.3, but don't recollect significant difference to earlier versions.
I'll check the figures if I get a chance.
Also intending to look at the SIO driver; sounds as if its done pretty much what I implemented in my modified serial driver.
- alex31
- Contact:
Thanks to all for the replies, I will rework my library (frsky fport bidirectional telemetry handler, will post it in contrib when finished) as suggested, with a state machine managed by the ISR and only post to thread complete messages. This will have a beneficial side effect : separate the state machine from the OS dependent code will make it more portable.
Alexandre
Alexandre
