Missing bytes over UART, any way to recover?
albinhj
Been thanked: 3 times
Postby albinhj » Fri Jul 28, 2023 9:55 am
STM32L4.
I'm using UART for time critical communication, where I at a regular interval send three bytes from one controller to another. There is a short pause between every transmission, where the data is being processed, before the next transmission is expected again.
I start the reception like this:
uartStartReceive(&UARTD4, 3, _rxbuf);
Then I have a receive callback, that processes this data, and then calls that same command again.
This works, mostly. But I also have some noise on my communication line (sometimes NOISE_ERROR gets triggered on the error callback), which I suspect causes my problems. What I'm seeing is that my reception gets unsynchronized.
For example:
I expect: 0xAA 0xBB 0xCC
I get: 0xAA 0xBB 0xAA, then 0xCC 0xAA 0xBB, for example..
It's seems to me like one of the bytes gets missed in one instance, and then I get out of synch, always reading three bytes but from different "packages" or something.
What I want is to receive three consecutive bytes. Is there a way to use the HAL driver to achieve this? Can an error be set by the driver? Or can I check somehow if this was the case?
Has thanked: 1078 times
Been thanked: 922 times
Re: Missing bytes over UART, any way to recover?
Postby Giovanni » Fri Jul 28, 2023 10:21 am
You need to manage timeouts in your protocol, errors happen.
A possible approach is to start a timer together with the receive operation and stop the receive if the timer is triggered.
albinhj
Postby albinhj » Thu Aug 03, 2023 3:39 pm
Small update. After some experimentation, I've found a way using the IDLE line detection to help me work around the problem.
Best regards
Return to “ChibiOS/HAL”
