I used linux, tomorrow I'll check windows environment.
Also I plan to use free Renesas e2studio (Eclipse-based) for debug, so we'll receive full development environment for Windows
Renesas RL78 port
Moderators: lbednarz, DeusExMachina
- DeusExMachina
- Has thanked: 3 times
- Been thanked: 3 times
- DeusExMachina
Re: Renesas RL78 port
2lbednarz
I checked my makefile in Windows, and it worked for me.
But before I received the same errors as you, and this errors were related to broken compiler and make environment.
So, first we should be aware of using make from yagarto tools. If you use 64bit windows and receive heap allocation errors, may be you have to rebase msys-1.0.dll using ReBase.exe from Visual Studio:
After checking that make is OK (for ex. compiling some ARM Chibios projects) we need to place libstdc++-6.dll and libgcc_s_dw2-1.dll to the same directory with make. rl78-elf-gcc needs these files to be located in the same directory with make!
Of cause this directory must be in $PATH system variable.
(Don't use make provided with rl78-elf toolchain)
So, my yagarto-tools dir looks like this:
After you obtain valid make environment you can easily compile RL78 demo. (Please update to last github version)
Now it works OK
Next step is to setup of debugging in E2Studio.
rebase -b 0x30000000 msys-1.0.dll
07/07/2006 03:45 AM 18,349 copying.txt
07/07/2006 04:00 AM 74,240 cp.exe
07/08/2006 10:54 PM 163 echo
11/22/2013 03:17 PM 108,032 libgcc_s_dw2-1.dll
11/22/2013 03:17 PM 879,630 libstdc++-6.dll
07/07/2006 04:00 AM 180,736 make.exe
07/07/2006 04:00 AM 28,672 mkdir.exe
12/05/2013 11:50 AM 781,616 msys-1.0.dll
05/13/2010 10:26 PM 55,112 ReBase.Exe
07/07/2006 04:00 AM 62,464 rm.exe
07/07/2006 04:00 AM 476,672 sh.exe
10/19/2006 02:19 AM 709 source.txt
07/08/2006 10:54 PM 38,400 touch.exe
Now it works OK
Hmm... too many things to do for me:)
I think, that tools provided by rl78 toolchain can work using sh.exe, but I've installed it in path with spaces (Program Files) and sh.exe seems to not accept that.
I've found that vectors.c, chcore.c and R5F100xE.ld are not included in compilation. Look at ARMCMx rules.mk file, there is "-T$(LDSCRIPT)" in LDFLAGS.
If you remove "-Wl,--relax -Wl,--gc-sections" from rules.mk LDFLAGS, you can see, that there are linking errors.
- DeusExMachina
lbednarz wrote:I've found that vectors.c, chcore.c and R5F100xE.ld are not included in compilation. Look at ARMCMx rules.mk file, there is "-T$(LDSCRIPT)" in LDFLAGS.
Fixed
rl78-elf-gcc ../../os/ports/GCC/RL78/crt0.o ../../os/ports/GCC/RL78/chcore.o ../../os/ports/GCC/RL78/vectors.o ../../os/kernel/src/chsys.o ../../os/kernel/src/chdebug.o ../../os/kernel/src/chlists.o ../../os/kernel/src/chvt.o ../../os/kernel/src/chschd.o ../../os/kernel/src/chthreads.o ../../os/kernel/src/chdynamic.o ../../os/kernel/src/chregistry.o ../../os/kernel/src/chsem.o ../../os/kernel/src/chmtx.o ../../os/kernel/src/chcond.o ../../os/kernel/src/chevents.o ../../os/kernel/src/chmsg.o ../../os/kernel/src/chmboxes.o ../../os/kernel/src/chqueues.o ../../os/kernel/src/chmemcore.o ../../os/kernel/src/chheap.o ../../os/kernel/src/chmempools.o ../../test/test.o ../../test/testthd.o ../../test/testsem.o ../../test/testmtx.o ../../test/testmsg.o ../../test/testmbox.o ../../test/testevt.o ../../test/testheap.o ../../test/testpools.o ../../test/testdyn.o ../../test/testqueues.o ../../test/testbmk.o ../../os/hal/src/hal.o ../../os/hal/src/adc.o ../../os/hal/src/can.o ../../os/hal/src/ext.o ../../os/hal/src/gpt.o ../../os/hal/src/i2c.o ../../os/hal/src/icu.o ../../os/hal/src/mac.o ../../os/hal/src/mmc_spi.o ../../os/hal/src/mmcsd.o ../../os/hal/src/pal.o ../../os/hal/src/pwm.o ../../os/hal/src/rtc.o ../../os/hal/src/sdc.o ../../os/hal/src/serial.o ../../os/hal/src/serial_usb.o ../../os/hal/src/spi.o ../../os/hal/src/tm.o ../../os/hal/src/uart.o ../../os/hal/src/usb.o ../../os/hal/platforms/RL78/hal_lld.o ../../os/hal/platforms/RL78/serial_lld.o ../../boards/RENESAS_YRPBRL78G13/board.o main.o -nostartfiles -T ../../os/ports/GCC/RL78/R5F100xE/ld/R5F100xE.ld -o ch.elf
rl78-elf-objcopy -O ihex ch.elf ch.hex
rl78-elf-objcopy -O binary ch.elf ch.bin
rl78-elf-objdump -x --syms ch.elf > ch.dmp
rl78-elf-size ch.elf
text data bss dec hex filename
32905 214 2228 35347 8a13 ch.elf
- DeusExMachina
I recompiled using last version of gcc (v14), and noticed that size decreased significantly (as promised).
BTW, we need only these options to receive optimized by size program:
all other options are included by default selecting Ox level.
http://gcc.gnu.org/onlinedocs/gcc/Optimize-Options.html
-ggdb -mmul=rl78 -std=gnu99 -fdata-sections -ffunction-sections -Os
Can you give more details? What is the binary size comparing to previous compiler version?
- DeusExMachina
I received 3% less code size for 14.2 version. But I find critical problem - generated code for massive arithmetic operations bloats tremendously - 3 times more than IAR. Just adding several floating points operations increase code size for 7-8K. Unacceptable... I think for RL78 Chibios should be ported using IAR...
Users browsing this forum: No registered users and 26 guests
