Tiva and ChibiStudio
Posted: Sun Mar 01, 2015 10:56 pm
I'm new to chibi. I used to code in proprietary OS (TI - RTOS). Could someone help how to setup the chibi (I'm using chibi studio) to use the TIVA port of chibi which is ported by Marco I believe).
So, assuming, I have download the tiva port via github, what should I do next ?
If i just open the demo project and build it, I got the below errors :
Makefile:79: ../../../../os/hal/hal.mk: No such file or directory
Makefile:80: ../../../../community/os/hal/boards/TI_TM4C123G_LAUNCHPAD/board.mk: No such file or directory
Makefile:81: ../../../../community/os/hal/ports/TIVA/TM4C123x/platform.mk: No such file or directory
Makefile:82: ../../../../os/hal/osal/rt/osal.mk: No such file or directory
Makefile:83: ../../../../os/rt/rt.mk: No such file or directory
Makefile:84: ../../../../community/os/rt/ports/ARMCMx/compilers/GCC/mk/port_tm4c123x.mk: No such file or directory
Makefile:85: ../../../../test/rt/test.mk: No such file or directory
Makefile:198: ../../../../os/common/ports/ARMCMx/compilers/GCC/rules.mk: No such file or directory
make: *** No rule to make target `../../../../os/common/ports/ARMCMx/compilers/GCC/rules.mk'. Stop.
14:33:55 Build Finished (took 646ms)
Thank you
Novita
Thank you
Novita
